Somatic Negative Optimist
I searched for a while but................
![]() CSV is blue ASC is green WUR is ? AAR is ? Frequency Valve = ? Thx. ![]()
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() |
freq valve is white, wur and aar are black, at least on mine.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Thanks Gunter and Scott
this is what I am doing tonight. Checking all the plug locations are right.
Brad W 1980 911 SC 1982 928 Auto 1982 928 5spd Comp PKG 2005 SLK 350 w/ AMG Pkg 2007 Hummer H3 |
What is the name of each part?
CSV = ASC = WUR = AAR =
Slumlord
I read the question and immediately thought. 'Oh, Gunther will answer this one...". Oops, I guess even he was stumped.
WUR=warm up regulator AAR= air advance regulator? |
Designer King
Warm Up Regulator
Cold Start Valve Auxiliary Air Regulator Airflow Sensor Contact All are CIS components
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Color Coding......
The color of the sockets & plugs for CIS components like WUR, AAR, CSV, Air sensor switch, etc. were not the same from harness to harness. While most of the CSV I've seen were BLUE, some WUR and AAR were in gray or black. I believe the color coding of the wires were consistently maintained but not the color of the sockets/plugs for CIS parts. A post recently showed a green color for the air sensor switch. And found a brown color too. So we can not use the color as a standard guide for the connectors unlike the wiring harness. Tony |
The differences may be due to an after-market replacement of the connectors because these Bosch parts are pretty common on other vehicles. I am sure that a newer SC harness would show the correct colors. These 2 seem to be fairly consistent: CSV = blue ASC = green That leaves us with black, brown and gray. WUR = gray ?? AAR = black ?? FV = brown ?? Of course, the length of some wires determines the location but it is possible to switch between CSV - ASC or FV - CSV or even AAR - WUR ?? If anyone has a newer type SC harness, please, check the colors. ![]()
Gunter I just put a new harness on my car and the only color connectors were blue and green. This was the one for the sixteen pin to the ALT, Starter, Blower Motor, and such.
O.K.
I clearly remember colors for the WUR, AAR and FV on a '82 CIS, just forgot which colors went where. Hmm...........it's a mystery. ![]()
Thread Tools | |
Rate This Thread | |
