svb svb is offline
964 Carrera 4 downsides?
I ready to add a second 911 to my garage. Its a 94 Carrera 4 factory widebody with about 80k miles on it. What am I looking at in terms of additional maintenance and longevity with a 4 versus a 2? Thanks.
Boxster Spyder
Old 04-19-2008, 09:37 AM
FenderGuy's Avatar
Looking into the 964 the only issue I found with the 4 is the all drive factor and its more costly to maintain. A PPI would tell if its been maintained well, make sure you check the heads on these cars for the issue they had with the gaskets
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 04-19-2008, 09:48 AM
spence88mph's Avatar
Also rennlist's 964 section holds a wealth of knowledge on these cars.
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 04-19-2008, 09:53 AM
dan79brooklyn's Avatar
The widebodys are a very limited edition and collectible as you probably know.
There is a website dedicated to them exclusively, can't remember the address though, sorry.
I think they are very cool and will retain their value.
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon
(new addition 1998 Mazda Roadster)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
Oracle's Avatar
The all wheel drive parts will wear so it will be more expensive to maintain (some bits are stupidly expensive).
The 4 is heavier and to track it you'll need to spend more to make it perform.
My opinion is that unless you live in a place that need an all wheel drive...
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 04-19-2008, 10:57 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The 964 C4 is highly complex compared to a 993 C4 driveline. You'd be wise to consider the 993 instead if you really want all wheel drive. To bleed the brakes on a 964 C4, I understand you need the Bosch Hammer since the brake hydraulic system is associated with the electrohydraulic (that sounds expensive, doesn't it?) all wheel drive system
A C2 is more familiar to the older 911 owner. Since you're in San Diego? Forget the C4. Get a C2 if you want a 964. You'll thank yourself for getting a C2, considering the handling differences.
Kevin L
'86 Carrera "Larry"
Old 04-19-2008, 12:07 PM
Don Plumley's Avatar
As has been said, some of the AWD bits are stupid expensive. I believe the accelerometers are $2K new, though some have success cleaning/repairing them if they go out.
But the 94 is well sorted, and widebody is nice. If the PPI checks out, you have good records on brake fluid being religiously changed, I'd roll the dice.
Don Plumley
M235i
Old 04-19-2008, 12:30 PM
