Registered Speed Offender
Crazy Horse's Avatar
Question Am I the only one having difficulty taking the clutch cable out ?
Hey group,
I went to remove my clutch cable and there is a plastic sheath protruding from both ends of the cable carrier tube. This plastic sheath is causing me problems. I put vice grips on the tranny end (back end) of the cable, but the clevis end (forward end) seems too big to fit through this plastic sheath.
Am I not doing something right? Is there a way to pull the cable out other than the way I am trying?
Any assistance would be greatly appreciated !
Crazy Horse
______________
1989 930
Old 04-20-2008, 01:56 AM
Evolved
Mo_Gearhead's Avatar
Perhaps a '79 is different that the earlier cars?
My '69 had a plastic sheath at the trans-axle/clutch cable end, but it is an integral part of the cable (appears to me to be there to protect the bare cable from abrasion?). It ALL comes out together on mine? Others need to opine.
Don't fear the reaper.
Old 04-20-2008, 03:47 AM
fred cook's Avatar
Clutch cable removal...........
You should be able to remove the clevis from the cable. There is a small locking nut that jams against the clevis that must be loosened first. Once the clevis is off the cable, the cable will pull out of the sheath from the engine end. Unless a previous owner put something on the cable, it should just pull out. Hope this helps.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-20-2008, 04:02 AM
Question Clevis is off
I have removed the clevis. The cable gets stuck because the boss binding the cable to the thread end is too large to fit into this "thin clear plastic sheath" inside of the black cable carrier tube.
Please help me - this is my work car - I need it back up as soon as feasible.
This has to be something simple.
Crazy Horse
______________
1989 930
Old 04-20-2008, 09:07 AM
Somatic Negative Optimist
Gunter's Avatar
Looking at the Bentley 301-5.
After the clevis and nut are removed, the old cable is pulled out fro the engine side.
No mention of any plastic sheath?
Do you mean the shield that's around the wire cable itself?
Both parts, inside wire and outside shield, should come out together through the guide tube when pulling from the rear.
Unless the old cable/sheath is really stuck in the guide tube?
Is it possible that the PO made some changes to the guide tube?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-20-2008, 09:41 AM
cantdrv55's Avatar
I have a '79 and I believe the plastic sheath is part of the cable. Can you push it through towards the front to loosen it in the tunnel then yank it out from the back?
Old 04-20-2008, 10:18 AM
clutch cable
I just changed mine on a 77 Targa. Plastic sheating was broken in 3-4 pieces. It was stuck partway in the tube, thought, oh s**t, I'm in trouble now! Vice grips on cable, near rear of tranny, taped flat of vicegrips with hammer, don't wail on it....came right out. Plastic sheating was brittle and came out in pieces. Greased new cable with lubriplate, installed no problem....patience is a virtue.
Old 04-20-2008, 06:01 PM
Smile Same worked for me...
Bob,
I ended up putting vice grips on the engine end of the cable - but I did have to wail.
I also found that the plastic sheath was brittle and broken into 3-4 pieces. The cable is back in and it is amazing how better it is working !
Crazy Horse
______________
1989 930
Old 04-20-2008, 06:09 PM
khamul02's Avatar
Blast from the past but I had the same issue. Love Pelican!
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 04-12-2015, 08:27 AM
