Sleep Deprived and Grumpy
jwernquist's Avatar
Dual Battery Questions - Help!!
Hey guys it's been way to long, My 73 was converted to a single battery many many years ago.
My new 72 has the connections for dual batteries still.
1: Do you need 2 batteries in order for the car to start? I thought so I just can't remember. One battery just fires up all the ignition etc, and the 2nd battery works the starter correct? So if you only have 1 it will not start?
2: I cannot find any replacement batteries locally, except 1 that might fit.
Any advice would be greatly appreciated. My memory is failing
JW
jwernquist@wi.rr.com
262.215.6547
Old 04-26-2008, 09:59 AM
Porsche Crest
The two batteries work together, not on separate circuits. Just be sure to tape off the positive terminal of the second battery if you use only one and leave the wiring for the second battery in place.
Charles
1970 911t
1962 356 S90
1964 Safari Rally Comet
Editor www.Bench-Racing.com
Old 04-26-2008, 10:12 AM
Band.
+1 you don't need 2. Undo the passenger one if you like and make sure you have the positive end safely insulated or taped up or something.
A Mazda Miata battery will fit in the battery boxes, but it's a little shallow. You can put a hunk of 2x6 behind a Miata battery and use your stock battery hold down hardware.
Of course, a 911 is a harder 'start' than a Miata, so you might be stressing the battery/alt a little bit more than the stock setup.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 04-26-2008, 12:54 PM
fastfredracing's Avatar
One of my customers has been using tractor batteries for the last 3- years( he owns a lawn equipment company) , but I think that he just found optima's that will fit. . Hope that helps
No left turn un stoned
Old 04-26-2008, 01:11 PM
FPB111's Avatar
I have had dual SEALED Miata batteries in my 1972 3.2S for 4 years with no problems.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 04-26-2008, 07:31 PM
FenderBender's Avatar
Single Battery
Odyssey pc1200. Plenty of cranking power, completely sealed, can be mounted sideways also. Costs approx. as much as 2 miata battery's and is much better in my opinion. (Battery's plus)
Disconnect the second positive cable from the drivers side positive clamp. No worries about tape wearing through. I left mine lay in the trunk.
Mike
'99 Isuzu VX, 2005 Audi A4 1.8T Quattro
'96 BMW 328ic
'73 911T Targa SOLD
www.flickr.com/photos/fenderbender813
Old 04-26-2008, 08:23 PM
Dual battery questions
Interstate makes a replacement for the OEM dual battery
Old 04-27-2008, 10:33 AM
Mark S
Interstate part #?
Old 04-27-2008, 10:54 AM
Interstate number U911-50
Old 04-29-2008, 08:52 AM
pwd72s's Avatar
Also, Sonnenschein, a german battery maker, produces gel cell totally sealed "exact fit" batteries for the dual battery early 911...available thru Ft. Lauderdale battery...sorry, lost their web address.
Old 04-29-2008, 10:06 AM
3 restos WIP = psycho
kenikh's Avatar
There's a lot of info if you Search, but I use the Sonnenscheins and really like them.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-29-2008, 10:47 AM
HarryD's Avatar
Originally Posted by HarryD View Post
The battery is not a "standard size".
Per Ed Mayo (http://www.early911sregistry.org/forum/showthread.php?t=16781&highlight=battery - August 2007): "The source for the Sonnenschein batteries is www.batterysales.com You want the DF-75 w/SAE posts, and the cost is $129.00 I have three 911's with two of those in each car, best money I've spent."
A search will turn up a wealth of information.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-29-2008, 10:26 PM
oops, replied in wrong thread!
B Shriver
http://foremostcarguy.blogspot.com/
Old 03-19-2010, 08:20 AM
As above, any 1 of several batt's will work BUT would like to add a word of caution on that additional hot lead.
Tape may work for a while is very dangerous. The end of the 2nd cable ties into the +clamp on the drivers side, REMOVE IT from the batt post clamp do not leave it in the system.
And if you want a clean look it is lead arounf the gas tank area inder the lip of trunk, VERY EASY to remove and take the other ground cable off the stud with the butterfly nut and clean up the trunk and it wont look like a kludge, as well as being SAFER.
That is what I did with my 71.
Regards
Old 03-19-2010, 10:40 AM
I am converting my 71T back to dual batteries and would like a pic of the correct connectors and diagram to be sure I do it correctly .I think(hope ) I saved all the parts .Thx in advance .Steve
Old 03-25-2011, 11:08 AM
Band.
I'm with Jerry,
Remove the Pass. side battery completely, and undo the thick positive crossover cable from the terminal post clamp on the Driver's side completely, tape both ends just because, even though you don't have to.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 03-25-2011, 11:21 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
buy two batteries, it's the way your car was designed.
Chris
73 911 E
Old 03-25-2011, 12:06 PM
abisel's Avatar
Chris
73 911 E
What Chris said.
For the 69 to 73 cars, they designed it for two batteries for corner balance reasons. Stick with the dual battery setup and use Sonnenschein.
A 500
get two of the 40 amp batteries in parallel for a total of 80 amps.
Old 03-25-2011, 01:41 PM
I have run 1 Interstate for quite a while (7years)in my '69 with a 2.7L. I expect I will need to replace it soon.
Only downside I see is it cranks too slow when below 25deg, but I don't drive it in winter due to salt.
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 03-25-2011, 02:19 PM
E Sully's Avatar
Here is a good thread. I personaly use the 2 Westco Miata batteries. They have been working great
Early 911 Battery Options
Ed
1973.5 T
Old 03-25-2011, 03:18 PM
