davis911s's Avatar
Placing an order.. What am I missing?
Ok I am placing an order for my car. Basic tune up stuff, the car has sat for 4.5 years and I will be getting it back on the road in the next few weeks.
Here is what I ordered
Fuel Filter
Oil Filter
Air Filter
New CIS airbox straps (cheapo's)
NGK Spark Plugs
Distributor cap
Rotor
Pertronix (replacing my points)
2 Oil drain plug seals
Alternator belt
Valve feeler gauge and spare blades
SILICONE valve gasket with new nuts and washers
First off can anyone think of something else I NEED? Secondly are the Silicone gaskets worth the little extra money?
Thanks guys I will be placing the order thursday, I just want to make one order and not miss something and it has been a few years since I tinkered.
Shawn
Medicine Hat, Alberta, Canada
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 04-29-2008, 04:10 PM
Alii&Maui
Jesset100's Avatar
Spark plug wires
brake rebuild kit
brake fluid, pads, flex lines and maybe new rotors
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 04-29-2008, 04:25 PM
Czar of C.R.A.P.
dfink's Avatar
As long as you are doing all that you might want to change the tranny fluid with swepco 201. Also after that long brake fluid to bleed the brakes.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 04-29-2008, 04:42 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Originally Posted by Jesset100 View Post
Spark plug wires
brake rebuild kit
I was thinking exactly the same thing. At the very least, check the pads and replace the fluid.
Before you get the car running, make sure you can stop.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 04-29-2008, 04:47 PM
