Placing an order.. What am I missing?
Ok I am placing an order for my car. Basic tune up stuff, the car has sat for 4.5 years and I will be getting it back on the road in the next few weeks.
Here is what I ordered Fuel Filter Oil Filter Air Filter New CIS airbox straps (cheapo's) NGK Spark Plugs Distributor cap Rotor Pertronix (replacing my points) 2 Oil drain plug seals Alternator belt Valve feeler gauge and spare blades SILICONE valve gasket with new nuts and washers First off can anyone think of something else I NEED? Secondly are the Silicone gaskets worth the little extra money? Thanks guys I will be placing the order thursday, I just want to make one order and not miss something and it has been a few years since I tinkered. Shawn Medicine Hat, Alberta, Canada
Shawn 77 Targa with 2.7 My never-ending work in progress that has been off the road since Mar 2004
Alii&Maui
Spark plug wires
brake rebuild kit brake fluid, pads, flex lines and maybe new rotors
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
Czar of C.R.A.P.
As long as you are doing all that you might want to change the tranny fluid with swepco 201. Also after that long brake fluid to bleed the brakes.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Monkey+Football
Before you get the car running, make sure you can stop.
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
