Re route oil line after header install?
Installing headers on the SC track car, and have found the rubber oil line lays almost on top of the tubes. How have others handled this? Try to re route it a bit and hold the center of the line up off the headers with some type of clamp? Fabricate a bent line out of metal? I am sure lots of others have come across this, tips wanted.
1979 911SC 3.2 SS Custom Backdate Hot Rod 1972 911T, 2.7RS Spec Beck 904 Carrera GTS /3.6 2023. Macan Previously owned several 911 models since 1975. |
Check out this link to another thread...it has the lines you'll need...2 of them. Our host sells them both.
Oil Lines
Woody Slow n Fast 1984 Guards Red 911 Carrera |
Do you have B&B Headers? You mention the rubber line ("S" hose) and this does interfere with the B&B Headers........ The solution is custom or get the replacement pipe from B&B.....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
here's a pic of the angled transition between the S hose and 3.6 block
![]() It would probably be a good idea to install aheat shield as well.
here's an installed picture, the angled pipe raises the S hose up away from the headers
Have you got a 3.0, 3.2 or 3.6 in the car in question?
Cheers
Less brakes, more gas!
-Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
