David 23's Avatar
Re route oil line after header install?
Installing headers on the SC track car, and have found the rubber oil line lays almost on top of the tubes. How have others handled this? Try to re route it a bit and hold the center of the line up off the headers with some type of clamp? Fabricate a bent line out of metal? I am sure lots of others have come across this, tips wanted.
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 05-02-2008, 04:24 PM
Thrlls's Avatar
Check out this link to another thread...it has the lines you'll need...2 of them. Our host sells them both.
Oil Lines
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 05-02-2008, 11:54 PM
Jeff Alton's Avatar
Do you have B&B Headers? You mention the rubber line ("S" hose) and this does interfere with the B&B Headers........ The solution is custom or get the replacement pipe from B&B.....
Cheers
www.turn3autosport.com
Old 05-03-2008, 12:11 AM
Bill Verburg's Avatar
here's a pic of the angled transition between the S hose and 3.6 block
It would probably be a good idea to install aheat shield as well.
Bill Verburg
Old 05-03-2008, 04:34 AM
here's an installed picture, the angled pipe raises the S hose up away from the headers
Bill Verburg
Old 05-03-2008, 01:24 PM
Jeff Alton's Avatar
Have you got a 3.0, 3.2 or 3.6 in the car in question?
Cheers
Old 05-03-2008, 03:49 PM
Less brakes, more gas!
euro911sc's Avatar
How in the hell do you change the filter? Take everything apart? what a PITA!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-03-2008, 05:43 PM
