Weber cleaning follow-up
I pulled the Webers off my '70T to do a quick inspection and to cosmetically clean them up, I had run some fouled gas thru when I moved the car out of storage and didn't want the whole mess to turn to varnish. I just used some conventional carb cleaner from a can and then lightly brushed the carb body with a wire brush. then I dunked the carbs in hot soapy water. My question now is, what should I lubricate the linkage with? anything else I should be concerned about lubricating before I run the car again?
thanks and regards, Jeff in Houston 1970 911T 1956 Chevy P.U. Truck IFS/327 Rat Rod |
1-6-2-4-3-5-1-6-2-4-3-...
Lithium grease. Just get all the ball joints on the linkage lubed and you should be fine. I didn't put any lubrication on the throttle shaft in a recent rebuild I did.
'70 911E Coupe, Webers 40IDA |
