joetiii's Avatar
Start of an alternator problem?
I noticed today that the lower red lamp on my oil pressure guage stays on when I first start up the car. I have noticed this in the past when starting but the light went out after I got the RPMs over 1500 or so. Today I noticed that the light stayed on even after I reved up the motor to 2k. Went out after 40 seconds or so by itself, regardless of RPM. Do I have a loose connection perhaps, or is something starting to go bad in the charging system??
joe
'69 911 E Targa - aka "RoxiE"
Old 05-05-2008, 06:20 PM
oneblueyedog's Avatar
It could be a diode in the alternator going out.
Or, in one case I had a wire from the voltage regulator pinch between the voltage regulator housing and the alternator body and that made the red light glow.
You could get it tested in the car to see what it's doing. You measure voltage over the battery terminals with a Voltmeter. With it charging I think it will read 14V. But check in the archives with a search. I think you check it with the lights on with engine running.
When I had a bad alt it read 12, 11.9, 11.7....then wouldn't crank.
78SC coupe, Silver Metallic
Old 05-05-2008, 06:35 PM
joetiii's Avatar
I think I'll start by tightening the belt, then test voltage at the battery. Will report back.
joe
Old 05-06-2008, 12:31 PM
joetiii's Avatar
So belt tension was fine and the voltage at the battery was 12.2 volts, so I changed out the alternator. $500 and it still tests 12.2 volts at the battery
What next????
Battery load is 620 cranking amps and shows 13 volts with the ignition key off
joe
Old 05-08-2008, 05:17 PM
Is the red light still glowing?
Old 05-08-2008, 08:11 PM
Is the Voltage regulator on the alternator or on the fuse/ relay panel?
Old 05-08-2008, 08:25 PM
joetiii's Avatar
The dash light stays on constantly. The ground strap is a bit worn but still solid on both ends. When the car is running, the voltmeter reads a little over 12 volts. When the car is off, the voltmeter starts to rise. I understand that there should be 12v at the starter and 12 at the lamp wire to excite the regulator.... now how to test?
joe
Old 05-09-2008, 02:51 PM
$500 for an alternator? Where can I get one? It must be gold-plated.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-09-2008, 04:14 PM
Typical Salesman
jeffrey2's Avatar
Joe - any luck? I took mine out for a leisurely commute today and the alt light came on; the alt is only about 3 years (and 1000 miles) old; hoping that's not the case.
"No Porsche should be subjected to the humiliation of a daily commute."
1979 SC Targa - Judy
2010 Lincoln Nav - The Purple People Eater
2008 MBZ E350 - Daddy-O
Old 06-16-2008, 07:50 AM
