993 widebody. Is this a Widebody??? Pictures inside
I was woundering did they ever make 993 widebody in the "Targa" trim???
Is this a Widebody? And what the easiest way to tell?
Old 05-07-2008, 03:02 PM
Bill Verburg's Avatar
no and no
that's a 94 or 95 n/b targa
Bill Verburg
Old 05-07-2008, 03:05 PM
Oh Haha's Avatar
No 993 Targas in "widebody" were produced by the factory, AFAIK.
Wide body 993's are known as C2s and C4s. The 2 and 4 designating 2 or 4 wheel drive.
Pacific Blue
Wayne
Old 05-07-2008, 03:06 PM
How much wider are they? Cause i Have a hard time telling them apart.
Old 05-07-2008, 03:09 PM
Oh Haha's Avatar
You should check out the 993 forum.
1997 C2 vs. 1997 C2S
Pacific Blue
Wayne
Old 05-07-2008, 03:13 PM
NEW QUESTION!!!!
What would you pay for the car pictured???
110K, 6 speed manual, Salvage title.
Old 05-07-2008, 05:37 PM
dzls rok's Avatar
i wouldnt. walk away. you can find a really nice, clean, low mileage 993 in your budget.
Old 05-07-2008, 05:42 PM
Bye, Bye.
Scooter's Avatar
Can you tell which one is a C2S and which one is not?
The fender appearance is very subtle when they are side by side, but I believe the widebody is 2.5" wider in the rear (edit: that's 1.25" per side). The tell-tale sign is the difference in the rocker appearance.
Elvis has left the building.
dzls rok's Avatar
there was one on craigs list san diego with 45,000 miles for $30k. and a pelican had one with a 100k miles but the suspension, brakes and exhaust were all done up for $32k. and jtkkz had a low mileage c2s for $37k if i remember correctly. just to give you an idea.
Old 05-07-2008, 05:48 PM
Don Plumley's Avatar
NEW QUESTION!!!!
Do a search under the username "Rattlesnak" - he did a very similar rebuild.
If you like to rebuild broken cars, can determine the condition of the engine, CEL issues, etc., and can do all the labor yourself, then it's probably worth less than $10K - parts value.
I'd be very concerned with repairing a Targa - that's one expensive roof if things are not working right due to the hit.
Nice wheels, they might be worth having.
Don Plumley
M235i
Old 05-07-2008, 05:57 PM
shahram's Avatar
Porsche944parts
sent you PM.
Old 05-07-2008, 06:54 PM
WI wide body's Avatar
I had a standard '96 993 Tip Coupe and the back of this car looks the same. Not sure if they even made any wide body targa 993's. I've never seen one.
Old 05-07-2008, 06:58 PM
beasty's Avatar
+1 i wouldnt even think about this 993. too much work...
'14 Cayenne GTS
'04 996 Coupe
'02 C4S Coupe
'99 M Coupe
'84 M491 Coupe
Old 05-07-2008, 08:06 PM
300hp 1800lbs is the goal
pksystems's Avatar
Low ball it :P
Course in Canada, cars at those salvage auctions go for ridiculous amounts
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 05-08-2008, 02:04 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
If you dont want it, Ill take it! That is a way easy fix. That being said, i would put the value of that car @ $8-10K tops. There are far too many decent ones out there for mid $20Ks now. Even if you were to spend @ $6k on it to fix it, (which i dont think this one needs) then you could resell it for @ $18-20k range and be ok.
~It all depends on how much you can do yourself. ~
Old 05-08-2008, 07:55 AM
The car is already at $11,300 for preliminary bid. It will easily bring $12-$14K.
110K miles
Salvage title
I think I rather get into DEPT!!!! LOL
Old 05-08-2008, 10:19 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Nope, that is a narrow body... only 993TTurbo, C2S and C4S were made in wide body (well, and a limited amount of cabriolets as I recently found out...)
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 05-08-2008, 11:56 AM
BTW, they call the 993 a targa, but it's really a sliding glass sunroof.
And it has many problems. Complicated. Much time/effort/money to keep it operating and not rattling.
Old 05-08-2008, 12:01 PM
