Yellowbird RS's Avatar
Installing Chain Tensioner Collars (need gap info)
I need to know the gap distance between the collar and the tensioner.
THX!
X/A
Old 05-06-2008, 07:18 PM
Scrappy's Avatar
It's set with that little metal plate in the image.
Ron Meier
Backyard Shadetree Mechanic
1974 914/6 conversion with 2.7L (The Grey Ghost)
1973 Chalon with 2.4T MFI (Schlitzalom)
All my 4 cylinders are gone
Old 05-06-2008, 09:33 PM
yes but I lost it ???
X/A
Old 05-06-2008, 09:46 PM
db_cooper's Avatar
I went through my tool box and found an old bar tensioner gauge "from the old days".
It is 3.3mm thick, which should be set once the tensioner is installed and to set the safety stop. Allows for some compression when the engine is off for a while. Anything more would be protected.
Old 05-07-2008, 05:35 AM
3.2 CAB's Avatar
That sounds like some helpful numbers, that a lot here should write in their Bentley Manual somewhere.
I had no clue, mine is a 3.2. I wrote it in my info notebook.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 05-07-2008, 11:20 AM
911quest's Avatar
If you can't find the tool it is two quarters stacked on top of each other.(Quick and dirty)
Tony Proasi
1969S
1957 VW Pickup
Old 05-07-2008, 01:47 PM
Whaddu we Yurrupeans do?
Old 05-07-2008, 02:46 PM
Oh, I know - hydraulic....
thanks!
X/A
Old 05-07-2008, 03:12 PM
db_cooper's Avatar
Your welcome. If you need the metal gauge, let me know. If you need to replace the tensioner(s) many, many miles down the road, try the new style Carrera.
Old 05-07-2008, 05:44 PM
thanks!
the metal gauge must be the same. right? which should be set to determinate the distance between the tensioner cillinder and the collar.
The Carrera tensioners are coming but I need to move my car this weekend to a local Porsche parade so this is just a temporary set up.
X/A
Old 05-08-2008, 11:39 AM
