Did you split your calipers when rebuilding?
I am about to rebuild some calipers I have. Did you guys split them when doing it? Any reason why that would be bad? Should I replace the bolts? If so where do I pick up a set?
I did not. Not sure why you would want to.
Once the seals are replaced, and the pistons cleaned up with scotchbrite, I put them back in. New rubber boots. Been that way for 3 years, no problems.
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
Vaccinated and Boosted
I believe I read that Porsche recommends that you do not split them. But I cant remember where I read this...
I rebuilt mine and did not split them....no problems! |
911 user...
i believe the information in the shop manual makes mention to NOT splitting them as sometime they don't seal like before... just rebuilt front and rears a couple weeks back and did not split them.
-Will 911SC & Audi S4 Count those blessings every night! |
"farking Porsche hero"
I had to split mine in order to hone the cylinders. I've done that on the last two sets I've rebuilt with no problems. I did replace the O-rings.
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
I just did the set on my '69. I did not split as the several sources I checked advised it's really hard to find the seal that go in the center and you'll likely have leaks if you don't replace the seals. I ordered my kits from Pelican and they did not come with the seals, so that made the decision for me.
As mine made moderate rust, it could have been much easier if I had split them, but I took my time and got them apart.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
