Guest
Posts: n/a
My weekend project is new tbars (27/21 mm), neatrix spring plate bushings, lowering, corner balancing, and some detailing. Good thing it is a 3 day weekend.
Well, day one is over and I thought you guys might like to see the progress so far. The rear tbars are out, the bushings are off, everything is cleaned up and ready to put back together tomorrow am. Here is a picture of the rear driver side tbar and spring plate coming out: The removal is pretty straight forward. Just unbolt everything and pull them out. Here is a picture of the spring plate bushings showing the wear: The car has about 85k miles and you can see there is considerable wear on the side of the bushing that is carrying the weight. With this much wear I can imagine their is considerable play when the suspension is loaded in a turn. Here is the other side of the same bushing: That is the side that carries no weight and you can see it is still squared up nicely. Based on my experience I would suggest anyone with 100k miles should thing about replacing these bushings. I am replacing these with the Neatrix bushings. I chose these because they don't squeak like the plastic bushings, but are a bit harder compound rubber than the factory bushings. I had my first ride in a car with plastic bushings yesterday. Boy did it squeak, I am really glad I chose the Neatrix. The squeak made the car seem like a rattle trap, even though it was plenty tight. Anyway, the factory bushings are a ***** to remove. There are probably as many ways to get them off as there are people willing to do the job. The tool that comes with the bushings is useless, throw it out. This worked for me: Use a razor knife and start by slicing across the bushing. Then run the razor knife around the shaft, kinda like coring an apple. Then run the knife around the radius. Now grab the flap with a pair of vicegrips as shown, and use the knife to slice the rubber away from the metal, peeling the rubber off in one peice. I imagine this is not unlike scalping someone. Anyway, you can now use the razor to shave off most of the remaining rubber. I then used a torch to burn the last bits of rubber, making them brittle, then sanded off with sand paper. Takes awhile but works fine. No pictures, but then I cleaned up with brake parts cleaner, then soap and water. Then painted the spring plates with aluminum colored engine enamel making them look like new. Everything is ready to go back in. No real problems yet, just a lot of work. I definetly made the job bigger by cleaning up and painting the spring plates. But I couldn't imagine having them out and not detailing them. Call me anal. That's it so far, I post another update tomorrow. ------------------ Chuck - '86 Cab, '77 Targa, Family Truckster [This message has been edited by Clark Griswald (edited 07-06-2001).] |
Guest
Posts: n/a
Keep the pics coming Clark! I'm following your pics and progress as I may do some of the same in the future.
thanks ------------------ 85 Carrera Targa |
Guest
Posts: n/a
Great pics, Clark! Makes me wanna do my bushings too... I imagine if Haynes had this kind of pictures nobody would be complaining. Thanks!
------------------ Jeff 1976 911S |
Guest
Posts: n/a
Here is the day 2 update. Didn't get the post up yesterday because of the server being down.
I cleaned up the spring plates and installed the Neatrix bushings. The clean up added a of time to the job, but I think you will agree it was worth while. The large hex head is the eccentric bolt that will be used to perform fine tuning of ride height later on. This shot compares the old 25mm rear bars (black) with the new 27mm bars (white). The size of the bar is stamped into the end and they are marked for Left and Right side. I'm doing my Micheal Jackson impression with the glove. I used that to coat to the bar with grease. The new rear bars are about 35% stiffer than the old. The new 21mm fronts are about 55% stiffer than the old 18.8mm fronts. The factory has kept the fronts at 18.8mm since, I believe, the late 60s cars. The rears have gotten progressively stiffer over the years, reaching 25 mm on the Carrera and 26 mm on the late turbos. The rears went together pretty easily. I set the factory adjustable springs plates in the middle so I could adjust either direction for fine tuning height and corner weight. This shot shows the springs plates going in. The key to doing this right is getting the proper angle on the spring plate so that when loaded you have (approximately) the correct ride height. Fine adjustments are made with the eccentric bolt. You will note the pencil marks on the wheel well. One is where I marked the position of the plate before I dissasemble. This was used as a point of reference when putting it back together. Scribbing that mark is VERY important, it would be hard to do this without that reference point. The second mark was scribbed after installation. The difference in angle will result in the change in ride height. I carefully compared the angle difference on driver and passenger sides to make sure they were the same. This is supposed to be the hard part. You take a guesstimate on the angle, put it all back together, lower the car and see what you have. Then if it not right, you jack it up and do it all again, and again, and again until you get it close to right. Fine adjustment can be made with the eccentric bolts. I got lucky and hit it right the first try. Here is the fully assembled wheel well: The cleanup was well worth it. Can you hear my brakes? They are screaming to be detailed. That is coming up. You can also see the SSIs that I previously installed, and the previously detailed valve covers. I put the wheels back on and checked the rear height. Close. I tweaked the eccentric bolts a couple times to dial it in. These eccentric bolts have a total adjustable range of around 3/4 inch. They are great for fine tuning, but to make any serious ride height change you must re-index the t-bars. Note, the early cars did not have adjustable spring plates. The process of setting ride height is much easier with the adjustables. I recommend upgrading to adjustable when you do this, either factory or aftermarket. Note, turning the eccentric bolts on factory adjustable spring plates requires a special wrench. It is a regular hex head, but it is thinner than a standard wrench. The wrench must fit between the spring plate and the inner wheel well, a standard wrench is just too thick and won't fit. Order the wrench before you start this project, it is available from a variety of Porsche specialty suppliers. You will need it. With the back end out of the way, I dived into the front. This is a much easier job. Easy to get the tbars out, easy to adjust. Here is a shot of the removal: This is a simple matter of removing the tbar adjusting caps (left side of image) and withdrawing the bar (right side of image). You do need to move the sway bar out of the way. Installation is "the reverse of removal" as my Hanes manual is so fond of saying. I also popped in a steering rack spacer to reduce bump steer. The spacers are the shiny and thick washer looking items. You can also see the turbo tie rods that had been installed previously. The front went really fast, maybe 1 hour. 'course I didn't do any detailing. Adjusting the front height is very easy, you just turn the bolt on the tbar cap. I had to tweak it a few times to get the ride height correct. The tough part about adjusting the ride height is that every adjustment changes all 4 wheels. You need to think about all 4 wheels before deciding to make an adjustment, and consider how your change will impact the 4. That was it for day 2. Day 3 will be corner balancing and final re-assembly of the rockers. ------------------ Chuck - '86 Cab, '77 Targa, Family Truckster [This message has been edited by Clark Griswald (edited 07-26-2001).] |
Guest
Posts: n/a
Looks very nice, I'm usually the same way, if something comes apart for any reason, everything taken off in the process has to be improved in some way, before going back in.
I hate doing something twice, and I've been successful in wasting my money, ahem, avoiding repeating work lately... ![]() I may be doing the same on the rear of my 944 if I get the time. Ahmet ------------------ It's all the driver... |
Guest
Posts: n/a
Gee thanks for the scalping reference, almost blew my breakfast. |
Guest
Posts: n/a
Sorry about the scalping reference. I just saw the movie "Nurse Betty" and it was stuck on my mind.
FYI, generally a good movie but with a gruesome scalping scene in which the process is explained. A bit disturbing. As I explained how to slice off the rubber.... the parrallel was clear. ------------------ Chuck - '86 Cab, '77 Targa, Family Truckster |
Guest
Posts: n/a
Wow, good work! What a great post!
One thing I 've noticed is on some Carrera's that tube stick WAY out compared to earlier cars...is it hard to get it out or there without having to remove the rocker panels or something?
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I believe the tubes were lengthened or re-positioned(?) to accommodate the G50 transmission.
The round cover on the rocker must be removed. This isn't hard, as once the end caps are removed, the rubber strip can be slid in/out as needed.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
chime
pca 30 year member,1977 porsche turbo body targa 56 vw ragtop oval 01 harley sportster 18 Chevy Colorado diesel BIG RED Firetruck and assorted v-dub ,porsche parts hoarder..LoL |
