Cracked Air Box
I've been chasing a problem for 6 months: my engine stalls frequently, usually at highway speeds, and usually under hard acceleration about 4000 RPM. And it bucks at 3 - 4,000 RPM. Based on great advice on this forum, I've done a lot of testing and inspection of fuses, relays, sensors, vacuum lines. I've replaced the DME Relay, I replaced the fuel filter. I added injector cleaner and water remover to the gasoline. I ordered new CHT and oxygen sensors from our host (they are not installed yet). Today I discovered the air box is cracked (see photo).
My question is: can this cause stalling and bucking? It's worse in hot weather and after the engine is warmed up.
'85 Targa
Pics
Old 10-20-2007, 01:26 PM
slodave's Avatar
I can only say this.... I have one (maybe two cracks) on the inside, like yours, but not to the edge. I don't have any of the problems that you are having. I really should epoxy the cracks, but have been super lazy!
Dave
Old 10-20-2007, 02:22 PM
schnellmann's Avatar
Nope
Any air leaking in through there would still be metered by the AFM barn door, so this can't be the source of your problem. It's basically just letting in unfiltered air. You might need to clean the AFM contact track, or move the wiper arm itself to another arc path arc. If you search, you will find the info you need to do it. Lots of people have the same issue.
Or else you may have a leak on the other side of the AFM - like a cracked or disconnected hose...
-Troy
88 3.4L Coupe
Old 10-20-2007, 02:26 PM
Porsche Crest
If you need a lower box, I have one
Old 10-20-2007, 02:43 PM
You have a cracked air filter housing. The cracked air box problem is limited to CIS engines only.
Running a cracked housing, as you have, is no different than running without an air filter and has no effect on mixture.
Cheers,
Joe
Old 10-20-2007, 02:49 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Time to pass to an adapter and a cone filter...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 10-20-2007, 03:15 PM
slodave's Avatar
Yes, this would be a good time, but I know that in California, we need to have the OEM unit on for smog checks. As well, you could switch it back before the test...
Dave
Old 10-20-2007, 04:37 PM
That's great. Thanks for all the responses.
'85 Targa
Pics
Old 10-21-2007, 09:43 AM
JB Weld or even duct tape should take care of the cracks ( air tight is all that's needed here ) and since it's hidden in the back, nobody would ever know unless you told them.
Cheers,
Jose'
74 w/86 3.2
Old 10-21-2007, 11:44 AM
I just tried JB Weld on this same problem and have noticed the JB Weld seems to not be sticking particularly well. Is there some type of epoxy that would work? I know some epoxies don't work on some plastics but I have no idea what type of plastic is used on the Carrera air box...anyone know?
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-02-2009, 10:36 AM
HarryD's Avatar
TIA
JB Weld should work.
Clean the area very well with Carb Cleaner, scuff the surface with fine sandpaper to give a rough surface for the JB Weld to bind, wipe it down with more Carb Cleaner to remove the dust and after the solvent is gone, apply JB Weld.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-02-2009, 11:12 AM
I used LOCTITE 2-part epoxy. I glued a small piece of aluminum about 3/32" thick) to the outside of the box to reinforce it. Seems to be holding up well.
'85 Targa
Pics
Old 05-03-2009, 11:37 AM
Designer King
Paulporsche's Avatar
CIS guys have used 3M 5200 Marine sealant on their boxes w/ good results. Someone reported he made a backer piece from pop bottle plastic, which is a type of polyethlene, to place behind the split.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-04-2009, 07:06 AM
the glue should have HDPE or PP on the bottle. 3M DP8005 is one type. not many glues melt into and bond with polyethylene/polypropylene.
206 637 4071
Old 05-04-2009, 07:42 AM
Good information, thanks.
Buck
'88 Coupe, '87 Cab,
Old 05-04-2009, 11:42 AM
