Gas Guage Sending Unit
My gas guage has been reading erractic lately so I pulled the sending unit for a cleaning.
Took it apart and found some varnish on the float slides. Checked guage out of the tank got great readings.
Put it back in and bolted down what I thought was OK. No readings.
Removed several times OK out of tank. Put it back no readings
Finally got it to work back in the tank if I barely tightened the nuts.
What would cause the unit not to read if the nuts were tightened more than they are now?????
BTW did replace the gasket
Old 05-13-2008, 08:26 AM
AutoBahned
RWebb's Avatar
bad ground or bad signal wire?
if tight = no sliding, seems there would still be a reading (tho static)
Old 05-13-2008, 10:07 AM
