1984-911 M491
Trog's Avatar
ITB's - How do they work
How is air-flow measured with ITB's? Does the Motronic (or equivalent) controller still need an air-flow signal to meter the correct amount of fuel?
Just wondering...
1984-911 TLC......SOLD
Old 05-13-2008, 12:09 PM
PRO Motorsports
Tyson Schmidt's Avatar
With no airflow meter, the computer relies on the throttle position sensor, intake air temp sensor, rpm, and manifold pressure (MAP) sensor to "estimate" the engines fuel requirements.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-13-2008, 12:44 PM
1984-911 M491
Trog's Avatar
So I guess I have to trash the Motronic and replace with aftermarket computer?
Old 05-13-2008, 03:26 PM
Jeff Alton's Avatar
That is what I did!
www.turn3autosport.com
Old 05-13-2008, 03:28 PM
Bill Verburg's Avatar
Originally Posted by Jeff Alton View Post
That is what I did!
what engine management are you using?
Bill Verburg
Old 05-13-2008, 03:32 PM
Jeff Alton's Avatar
My 3.4 runs on a Micro tech. Very stable, reasonably priced and easy to use soft ware.
Cheers
Old 05-13-2008, 03:34 PM
Cheers
what throttle bodies are you using?
Bill Verburg
Old 05-13-2008, 03:37 PM
Jeff Alton's Avatar
jenvey
Old 05-13-2008, 03:40 PM
1984-911 M491
Trog's Avatar
Can I continue to use the Motronic to control ignition, and use another controller for the ITB fuel delivery?
Old 05-13-2008, 05:50 PM
Any response for this?
I'm considering acquiring a used kit consists of Jenvey ITB and Haltech F10 ECU among other stuff.
'87 3.2 Targa
Old 09-28-2008, 11:50 PM
spence88mph's Avatar
I am going to use one of these when I get around to it to replace my AFM, www.mapecu.com, just wish i had the time to tinker.
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 09-29-2008, 02:06 AM
