911 SC Odometer Just Quit
Hey Folks
My odometer (normal) and odometer distance reset (000- 999) quit while driving along on the weekend. Speedo is fine, all other clocks/ guages are fine. Any ideas? Fuse, relay, internal to clock itself? Somethinhg (where)? Relay/ unit on the tranny? If so, where the heck is it?
Cheers,
Steve in Calgary
83 SC Coupe
Old 05-20-2008, 10:34 AM
naturally aspirated
Palum6o's Avatar
Odometer gear. Many good threads on this topic and some really good step by step instructions on how to diy. The easiest thing to do is pull it out and send it to North Hollywood and while its there, have them calibrate it.
Old 05-20-2008, 10:39 AM
Anachronistic Anomaly
lfot's Avatar
+1
IG@ the_derek_whitacre
Old 05-20-2008, 10:47 AM
Thanks guys. You don't think it's anything at the back end of the car?
Old 05-20-2008, 11:21 AM
lfot's Avatar
It's a common problem. Cheap little plastic gear in the speedo breaks. It's quite a task to open up the speedo without the proper tools. Easier to send it to North Hollywood Speedo.
BTW... I have the same problem. Just haven't gotten around to taking it all of 2 miles up the street to get it fixed.
Old 05-20-2008, 11:23 AM
lfot's Avatar
Also...
Here's their website with contact info:
http://www.nhspeedometer.com/
Old 05-20-2008, 11:24 AM
Thanks again. Wish I were as close as you! Guess I'll give them a ring, box it up and ship it the few thousand miles to Hollywood from Calgary! Some of the guys with Porsches up this way have dealt with them before with good results.
Old 05-20-2008, 11:36 AM
If the speedo works but the odo does not, it's the broken plastic gear.
Be sure to draw a diagram w/ wire connection locations and colors and/or take pictures of the back before you disconnect them.
Old 05-20-2008, 11:37 AM
JasonF's Avatar
North Holly Speedometer provided me with great customer service when I needed to replace my speedo glass several weeks ago....highly recommended.
1995 C4/Guards Red (sold)
2005 997 Carrera / Arctic Silver (sold)
1995 C4/Polar Silver (sold)
2010 Cayman S / Atlas Grey (sold)
Old 05-20-2008, 11:41 AM
Right - good reminder - thanks. I've done that before when replacing the little bulbs in the clocks. Finicky stuff.
Old 05-20-2008, 11:44 AM
As others have said; odometer gear. I did it myself by ordering the gear from http://www.odometergears.com/ (talk about a niche business). Carefully pried the ring off the speedo and disassembled it over a clean white towel noting how the parts went together. Stuck it all back together apart from the glass, took the car down the road to one of those nifty radar speedboards the government like to set up on busy throughfares and used it to calibrate the speedo needle. Buttoned it up completly and its worked fine everysince
'83 SC Coupe
Old 05-20-2008, 12:05 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
mine died the week i got my car. i ordered the gear. could NOT fix it myself. and i consider myself pretty handy with fixing such things. just could not get it in there. sent it to a place on the east coast..maybe called eastern electronics? maybe in pennsylvania. had it fixed in less than 1 week for like $150 with calibration and they touched up my scratches to the metal ring. i think i sent it to a place different than where every one else sends it because the turn around was quicker. call around for turnaround times if it matters to you. i didnt care for driving without a speedo....tickets....
EDIT: i also recall while trying to fix it, i gently touched the needle and badly messed it up. very fragile. personally, i think it was worth the money to have a pro do it properly
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 05-20-2008, 06:49 PM
Thanks Scott. Agreed. Your story more or less emulates what I've heard from others. My fellow Canuck, Dave, from Kingston, Ontario is a brave man! I spoke with North Hollywood, and have decided to box it up and send it to them. $130 for the gear, cleaning and calibration. BTW, there is also Palo Alto Speedometer outside San Francisco.
Old 05-21-2008, 08:13 AM
Deluxe Speedometer in Denver is VERY good. Less than 24 hour turnaround. $130.
Old 05-21-2008, 08:49 AM
m_wuebben's Avatar
Do it yourself. 3 hours and the price of the gear. Draw a diagram when you pull it apart. Cheers, Mike.
1981 911 SC Black / Black & Tan sunroof coupe.
Run like the wind...straining the limits of machine and man... (Peart)
Old 05-22-2008, 09:15 AM
