LinkBack | Thread Tools | Rate Thread |
Spring plate height adjust via eccentric w/o removing other bolts, nuts?
Just installed brand new neatrix and stiffer t-bars.
want to fine tune ride height by turning eccentric on the spring plate. Do I need to remove spring plate-to-lower control arm bolts/nuts and camber/toe bolts/nuts as well as shock bolts? or can i just do it without taking these five bolts/nuts out? did unsuccessful search... :-( ps...do not consider rear spring plate bushing replacement job a half day work...I soon realized I opened a can of worms!!! but now I'm happy with everything got back together with more new parts. ;-)
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
You do not need to loosen the bolts that secure the spring plate to the trailing arm, or the shock bolts, or the toe/camber bolts.
You need only loosen the qty 2 22mm bolts that secure the two halves of the spring plate together, just aft of the torsion bar. The one closest to the tursion bar is a clamping bolt, the one further from the torsion bar serves as a clamp and eccentric.
Chuck Moreland - elephantracing.com - vonnen.com |
Thank you, Chuck!!!
