Burint's Avatar
930 calipers on rear SWB?
Will there be any modification, I can put 930 calipers onto the rear of SWB car?
I guess not, ha?
The Unbreakable RS/RSR door pull http://thaiporsche.shutterfly.com/776
86, 930.
70, 3.2.
67, 911.
Old 05-29-2008, 12:57 AM
djpateman's Avatar
I believe that the caliper mounting holes will not match. The SWB cars had very narrow spacing, and the 930 calipers have wider spacing than the usual 3" on the rear.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 05-29-2008, 05:52 AM
ennisk1's Avatar
I guess the only question I have to ask is..."Why"? I can only assume that you've put a ginormous motor in your car.
Keith
1978 911SC Dirty Penny
Old 05-29-2008, 07:07 AM
Burint's Avatar
Keith,
The motor isn't that big. It's the 2.7. pmo 46.
We now have the SC calipers, the dual circuit m.c. none boosted (don't want the booster in the front trunk for the period looks).
The S.C. brake set up is enough for cruising around but not o.k when tracking.
If the 930 calipers fit, we'll upgrade the m.c. to 23 mm. Mercedes truck.
86, 930.
70, 3.2.
67, 911.
Old 05-29-2008, 07:24 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Can SWB cars accept the aluminum trailing arms from later cars? If so i'd get a set of those (dtw has a set from an SC for cheap) and then you can put the 930 calipers on like this:
http://www.rebelracingproducts.com/Brakes.html
or like this
http://www.vehiclecraft.com/Brakes/930T_mod.htm
Kevin L
'86 Carrera "Larry"
Old 05-29-2008, 09:14 AM
