Born to Lose, Live to Win
rattley window
when my driver side window is about half way up, it rattles a bit over small bumps. is there something i can adjust or is it something i have to live with? thanks
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
My guess would be the bracket the secures the main post has broken. The main post is the part that divides the vent window from the main window. At the bottom of that, inside the door is a bracket that often breaks and rattles.
You need to pull the door panel and look inside the speaker hole to find it. Takes an allen wrench to pull it. |
thanks. ill check that out. but note: i dont hear anything rattling inside the door. the window itself, as it sits half way up, rattles a little. like its isnt sitting tightly
Take a look at the window channels. I suspect some of the felt is missing.
JR |
that sounds accurate. i need to remove the door panels or just inspect the window frame? i dont recall seeing anything wrong with the actual window frame...at least, i know there is no material missing that is visible
JR |
ok. thanks. ill look closely after work. i suspect ill just leave it alone. usually the window is either all the way down or all the way up and doestn rattle...im just being picky i guess
I had the problem on the driver side. I fond a thread that iscussed all the possibilities. One was a simple adjustment of the mechanizm. There are to bolt heads about 2 inches apart n the middle of the door panel removed). I made very slight ajustments to them and tested fo rattle. It was gone and has not eturned. Wish I could be mor technical but you may want to look at a manual or find hat thread.
Good luck.
Scott '86 911 Carrera Coupe, PCA, PBC |
