Brake sensor disconnect, how?
On a 85 Carrera, how do you dislodge the ware indicator form the brake shoe.
Dose it pull out or do you squeeze the two metal barbs or something?
Thx.
Old 06-06-2008, 01:21 PM
pgeorgeson's Avatar
I just wiggle it and pull it out.
1964 356 C
1970 911T
1974 914 2.0
1986 Carrera Spec911 race car #76
1990 Carrera 2
Old 06-06-2008, 01:41 PM
That's it?
Cool and done.
Old 06-06-2008, 02:02 PM
get a mini screwdriver behind it. then use your thumb as a prying point. may break, may not. bakelite rocks.
206 637 4071
Old 06-06-2008, 03:45 PM
Ok, I tried the pull thing. Did not want to come out. Then tryed to gently pull out w needle nose pliers. Broke the first one.
Did get the other to come loose.
Rears were easy as the pads seemed new.
I think what would have helped would be to spray them with brake cleaner or wd 40. It may be that the heat kind of welds them together.
Old 06-06-2008, 05:06 PM
