Brake sensor disconnect, how?
On a 85 Carrera, how do you dislodge the ware indicator form the brake shoe.
Dose it pull out or do you squeeze the two metal barbs or something? Thx. |
I just wiggle it and pull it out.
1964 356 C 1970 911T 1974 914 2.0 1986 Carrera Spec911 race car #76 1990 Carrera 2 |
That's it?
Cool and done. |
get a mini screwdriver behind it. then use your thumb as a prying point. may break, may not. bakelite rocks.
Ok, I tried the pull thing. Did not want to come out. Then tryed to gently pull out w needle nose pliers. Broke the first one.
Did get the other to come loose. Rears were easy as the pads seemed new. I think what would have helped would be to spray them with brake cleaner or wd 40. It may be that the heat kind of welds them together. |
Thread Tools | |
Rate This Thread | |
