Blap Blap Blap on decel - 79Sc ROW
Here's the deal.
dual In and Outs NO cat. Idles well.after initial warm up of about 2 minutes when it's dead cold. Always starts right on first crank. Exhaust doesn't burn my eyes or smell like fuel. On decel or as soon as I get of the gas a little at all i get a blap blap blap. I get a bit of a gurgle and a smaller blap f i hold it at around 3000 rpm on the hwy. hard accel it seems to be fine. Is this a sign of too rich? Is this just a sign of a very free flowing exhaust? Whats up. Am i paranoid because nothing has gone wrong lately.
JOHN 79 EURO SC "24 Years Later - The Dream Came True" |
Max Sluiter
Cat bypass = more open exhaust = leaner mixture and exhaust
this amplifies the natural "blaps" of CIS on the over-run which cannot be heard normally due to muffers, cats, and airboxes. CIS= continuous injection system It keeps pumping fuel even when the throttle is closed according to how much air is passing the metering plate. When you get on the throttle a little, the fuel burns in bursts.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max Sluiter
Its normal, though. I would not worry about it too much. Get a check out with an LM-1 air/fuel mixture tester too make sure you will not burn a piston or get detonation or bad stuff like that. This is just a precaution.
Flieger,
Thanks that makes sense.
What the ?
That it what i love about my cat and muffler bypass. My Harley does it too and it has a freeflow exhaust too.
SCWDP 73 1980 SC Harley Davidson Road King 9/11/01 FDNY/343 Never Forget! |
Born to Lose, Live to Win
my motorcycle does it on deceleration. music to my ears.
ive got a cat bypass but with a stock muffler on my 911 but cant hear the gurgling or pops. hoping when i get a new muffler that i will be able to hear it
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
check the timing too. retard may do it too.
Mine is almost exactly the same set up as yours - SSI heat exchangers with dual in-dual out sport exaust and no cats. Makes exactly the same sound you describe - and I love it
![]() Tried adjusting the mixture and timing up and down, but it is optimal right where I've got it and it always has that little blat-pop decelerating if you come off the throttle quickly at around 3500 rpm.
"Making things easy is hard work" My current stable: 1991 Carrera 4 Cabriolet, 1992 Mazda Miata, 2004 Lexus RX 330, 1994 F150 4x4 Supercab Also rans: 1977 Carrera 3.0 (traded for C4 Cab.), 1983 944 (project car - sold) |
Designer King
Can someone confirm that in a CIS car this usually means the mixture is too rich, or as Flieger says, too lean. Other posts have stated that intake backfiring is usually a sign of too lean whereas exhaust backfires come from being too rich.
JohnB911, Have you got any other too rich symptoms, like a hunting idle or a very black tail pipe?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
RETIRED
Decel popping can ALSO be an exhaust leak and unfortunately head studs.....so if your fix doesn't work check for that.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Black and Blue
If you havent had your CIS mixture adjusted since the addition of the of the exhaust system, I would encourage you to check with a gas analyzer and make sure your timing is right.
I would hate for you to burn up a piston.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
