peritus's Avatar
Q: What happens when you hammer it in third?
A:
James
91 Black on Balck 964 C4 (DD)
82 Metallic Red SC 3.6 Varioram (sold)
Old 06-09-2008, 05:04 PM
Non Compos Mentis
That's why I always hammer it in 2nd when autocrossing.
Old 06-09-2008, 05:06 PM
Mitch Leland's Avatar
Is the 3rd gear smaller or weaker than 2nd?
Thanks,
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 06-09-2008, 05:38 PM
peritus's Avatar
No, it comes down to personal preference... that is, what is the preferable gear to smoke a Corvette. LOL
James
Old 06-09-2008, 06:00 PM
Band.
Are you sure you don't mean:
Q: What happens when you hammer it INTO third?
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 06-09-2008, 06:41 PM
Band.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 06-09-2008, 06:42 PM
Max Sluiter
Flieger's Avatar
Why would you want to hit your 3rd gear with a hammer? You must not like it very much. Try swapping the ratio if you are unhappy with its character. Until then, it will work much better if you turn it, not hit it.
Old 06-09-2008, 07:43 PM
peritus's Avatar
I should have named this post, "What happens when you let your girlfriend drive your Porsche!".
(I hope my girlfriend isn't surfing Pelican in the next room)
James
Old 06-09-2008, 08:32 PM
the the is offline
That's most definitely NOT from hammering it while in third. That could never happen. It's from hammering it into third.
Old 06-09-2008, 08:38 PM
peritus's Avatar
Nope
James
Old 06-09-2008, 08:48 PM
Immature Member
dentist90's Avatar
Those little dog teeth are the things that break off when you force a gear. The damage above is what happens when one of those little dog teeth get between the driven gears! Any other damage??
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
peritus's Avatar
high hp and 25 year old machinery (that also had an affair with a 3.8 some time ago) is a troublesome combo...
James
Old 06-09-2008, 08:50 PM
peritus's Avatar
not really. the dog teeth are fine. the prob was really isolated to the 3rd gear set.
James
Old 06-09-2008, 08:52 PM
the the is offline
Originally Posted by peritus View Post
Nope
yep.
Old 06-09-2008, 08:55 PM
gearhead
Dentist's asking about the condition of the teeth on the idler gear that is the mate to the gear you have posted. It's pretty rare for teeth to just fracture off the main body of the gear without an instigator. The instigator is usually teeth breaking off of the engagement gear (or dog teeth) which is pressed onto the idler gear and is a seperate peice. Another common cause is for teeth to snap off of the operating sleeve as it engages with the dog teeth.
Either way it is still accurate to say that this is what happens when you hammer it into third, but this is the end result. The cause isn't pictured. Show us pictures of the mate idler gear and the op. sleeve and hub.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-09-2008, 08:59 PM
the the is offline
Yup.
Old 06-09-2008, 09:04 PM
Pics of girlfriend who slams Porsche into 3rd are required at this point
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
peritus's Avatar
James
Old 06-09-2008, 09:06 PM
peritus's Avatar
There she is!
James
Old 06-09-2008, 09:10 PM
Immature Member
dentist90's Avatar
Didn't find any of these in the bottom of the tranny?
mmmm.... crunchy! Coulda possibly come off a different gear, too. Hopefully none of the other gears choked on the debris. Don't forget to check the diff case carefully too!!
Old 06-09-2008, 10:18 PM
