mca mca is offline
mca's Avatar
How do I remove old case sealant from mating surfaces?
I am preparing to put my engine back together. After having the case washed at the machine shop, I spent an additional 30+ hours cleaning by hand.
I still can't seem to get the old sealant off of the mating surfaces. So far I have used a plastic sponge and plastic scraper with brake cleaner.
Is there a particular product that I should be using? I was considering trying to apply some heat with a propane torch if you all think that it will help.
Any suggestions?
Thanks,
Craig
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 06-10-2008, 04:26 PM
gearhead
Both Permatex and Hurth make a spray gasket remover. It's pretty harsh stuff but does the trick. You spray it on, let sit and bubble for 5 minutes and scrape.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-10-2008, 05:14 PM
Single-edge razor blade, very gently.
David Porter
Glyndon MD
'72 911T Targa
Old 06-10-2008, 05:44 PM
Stressed Member
Scott Clarke's Avatar
Craig-
Do you have Wayne's engine book? I can't remember what it recommends, but I found Scotchbrite pads to be a good way of getting old gasket stuff off.
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 06-10-2008, 06:12 PM
schnellmann's Avatar
I used all of the above plus a Dremel on low speed with a soft brass brush. That worked better than all the chemicals combined, especially removing the hard fiber gasket remains on the chain housings. Very easy and precise. Obviously you have to take care not to carve divot in the surface, but that's why you use brass and not steel brushes.
I'll say it and I don't care who knows it - I love my Dremel.
-Troy
88 3.4L Coupe
Old 06-10-2008, 08:06 PM
gearhead
I use that for the final pass to remove whatever hasn't come up with the chemicals and my plastic putty knife.
1974 914 Bumble Bee
2009 Outback XT
Old 06-10-2008, 08:24 PM
mca mca is offline
mca's Avatar
Thanks for the info. Nice array of input!
I do have a dremel but not sure if I have a brass fitting.
Old 06-11-2008, 05:28 AM
dtw dtw is offline
GAFB
Air grinder w/roloc scotch-brite disc.
Several BMWs
Old 06-11-2008, 05:41 AM
You can get both the scotch-brite and brass brush attachments for the dremel at Home Depot or Lowes, etc for a couple bucks each. Or, you can get a huge kit of them at Harbor Frieght for less than $20.
Good luck!
-Troy
88 3.4L Coupe
Old 06-11-2008, 06:54 AM
mca mca is offline
mca's Avatar
Good luck!
Great! Thanks.
Old 06-11-2008, 09:01 AM
Otto's Avatar
MEK will do the trick.
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 06-12-2008, 08:46 AM
Slumlord
Porsche_monkey's Avatar
Red Scotch Brite pad + brake cleaner. I would avoid any and all power tools in performing this task.
Old 06-12-2008, 11:02 AM
Nine9six's Avatar
Originally Posted by davidporter View Post
single-edge Razor Blade, Very Gently.
+1...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 06-12-2008, 11:10 AM
