Tweak Idle from 650 to 800 RPMs
My 86 911 runs great and has no issues except what the idle is low @ 650 once the car warms up. With the idle at 650 it is to low for the alternator to run correctly.
How can I just tweak the idle to 800? Is there a quick easy way?
Dan Ralph 86 911 Coupe |
1984-911 M491
I have a similar problem, low idle once engine has warmed up. The car runs fine, just low idle.
I know of no way to raise the idle as it's set in the Motronic. I wonder what's forcing it to idle so low? Must be a bad sensor reading?
1984-911 TLC......SOLD |
Maybe mixture out of whack ? - do a search: there is a way to set the ICV to its center position and then adjust the air bypass screw in the AFM for proper idle base speed. Check Steve Wong's website 911chips.com for details.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
1984-911 M491
That's what I thought, but I checked my CO and it's about 1.5%.
Thanks for all the info!!
I will check it out ASAP, and get back with a post
Member 911 Anonymous
It sounds like it maybe running too rich.
I would check the base idle by jumping connections "B" & "C" in the driver side engine bay. it is the open relay socket. Once plugged in it should by pass the O2 sensor & ICV and you can verify if she is trully set at 800 RPMs. If set at 800 RPMs: remove jumpered wire, Adjust the Air/Fuel mixture on the AFM. Clockwise to richen, Counter Clockwise to lean. then check RPM's again If base idle is lower than 800 then simply raise the idle but you need to check air/fuel mixture so she wont run too rich. Caution, do not over lean her, it may damage the cylinder heads I literally drove around doing this until I got to close to proper settings to eliminate sub-dips of my idle but using a CO reader would be the best tool for this for accuracy. My ghetto 2 cents, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
So your mixture is out of wack. Spec is 0.8% CO before the cat. If you're getting 1.5% after the cat, you're way rich. Last edited by stlrj; 06-05-2008 at 04:23 AM.. |
1984-911 M491
My cat has been removed. I believe 1.5% before cat is reasonable?
Trog...
Spec is 0.8% CO BEFORE the cat. Do you still have a lambda (O2) sensor hooked up? Last edited by tcar; 06-09-2008 at 10:33 AM.. |
The Porsche workshop manual say idle CO% should be between 0.6% and 1% and hydrocarbon < 300ppm. And that is before the catalytic converter with the O2-sensor disconnected.
1.5% CO and no cat...how do you get it to smog?
1984-911 M491
I'm exempt from smog-testing as my car is deemed a "Collector". Plus out here in BC-kanada, I believe any vehicle built before 1988 does not need to have a cat.
1984-911 M491
Sorry, yes my O2 is still connected.
1984-911 M491
BTW, an 1984 passenger vehicle with a 3.2Ltr engine weighing 1300KG only has to meet these emission standards in BC:
Driving Mode HC Standard: 213 parts per million Driving Mode CO Standard: 1.48 percent Driving Mode NOx Standard: 2159 parts per million Idle Mode HC Standard: 380 parts per million Idle Mode CO Standard: 4.33 percent My idle was 1.5%CO, well below our limits. My concern is fouling plugs.
Is there a way to read the Voltage, resistance, or current off the CO2 monitor that sits in front of the Cat. to know if you are between 0.6 and 1.0% without having a CO2 meter?
I have a Volt/Resistance/current meter and I'm license to use it!!! I don't have a CO2 meter.
Im trying to understand when I will know I have the Air/Fuel adjustment right!!
what is a sub-dip. Is it when you let off the gas the idle drops below 400rpms for a sec. them jumps back to the normal idle?
Dan,
the response function of a narrow-band O2 sensor is very non-linear and doesn't really lend itself to do a mixture measurement with a voltmeter. The sensor produces a voltage close to zero when lean and close to 1 volt when rich. It is like a step-function Read and see here http://www.aa1car.com/library/o2sensor.htm What you really need is a wide-band O2-sensor or a gas analyzer. These have a much more linear responses. Cheers, Ingo
I’m looking for the place I jumper out connections "B" & "C" in the driver side engine bay. It is the open relay?. I posted a pick of the open relay ! Can someone explain where "B" and "C" are so I can jumper them. There aren’t indicators on the panel
socket. ![]()
Yes correct. Read here on Steve Wong's website. It is explained well and there are the pin designations, too http://www.911chips.com/dmeconvr.htm
