Follow me
seymore's Avatar
Changing oil for the first time
The question I have is. I'm assuming the drain plug is righty tighty, lefty loosy. But for some reason its on there really tight. so I wanted to ask before I mess something up. Is there a trick or any advice that someone can give me to help get it off? Thanks Jake
Old 06-13-2008, 01:02 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Hmmmm, Sounds like PO or Wrench over torqued it. Make certain it is the correct socket and use and extension to get leverage.
The Torque Settings are:
Crankcase 52lbs
Oil Tank 30lbs
It will seem light but do not over torque it. Oh yeah use new oil plug gaskets
ALso do not over fill the oil. 10.5 quarts. You must bring it up to normal operating temperature and running to check the levels.
Above is for 84-89's
'85 Carrera Targa
PCA/POC
Old 06-13-2008, 01:04 PM
Follow me
seymore's Avatar
Im am pulling as hard as I can and it wont budge!
Old 06-13-2008, 01:17 PM
Cheater bar!
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-13-2008, 01:21 PM
DRACO A5OG's Avatar
Put a pipe on the end of your ratchet and pull. (Ghetto Extension) Make certain the socket is the 6 sided one not the universal type
'85 Carrera Targa
PCA/POC
Old 06-13-2008, 01:23 PM
DRACO A5OG's Avatar
Originally Posted by yelcab1 View Post
Cheater bar!
Too Funny, You Crazy
'85 Carrera Targa
PCA/POC
Old 06-13-2008, 01:26 PM
Follow me
seymore's Avatar
Breaker bar did the trick! Now I dont have new gaskets but the ones that are on there now look perfect. Do you think they will be ok. and also I live in DC with stop and go and blazing heat. has anyone used 20-50 oil and did it keep you cooler? Thanke for all the help guys! Jake
Old 06-13-2008, 01:35 PM
What he said...
get behind the passenger side rear, put your feet on the bumper and pull w/ a cheater bar.
make sure the oil pan is under it.
make sure there's a pillow on the floor for your head when it lets go.
Old 06-13-2008, 01:36 PM
Follow me
seymore's Avatar
I found out you have to push towards the drivers side! woops!
Old 06-13-2008, 01:38 PM
DRACO A5OG's Avatar
Congrats, just make certain you use proper torque on those puppies for future acts of love.
Yeah, it will be OK but please next time use new ones. The PO/Wrench over torque may have damaged it where you can't see it. My 2 cents.
I use Brad Penn 20/50 and it definitely keeps my baby cooler but be aware that it will take longer to bring up to Proper Operating Temperature (1st middle dash or 8:00 o Clock)
'85 Carrera Targa
PCA/POC
Old 06-13-2008, 01:40 PM
DRACO A5OG's Avatar
That would be Lefty Loosey (counter clockwise)
Try never to push only pull on a wrench.
'85 Carrera Targa
PCA/POC
Old 06-13-2008, 01:41 PM
Follow me
seymore's Avatar
Thanks. You guy have been a great help.
Old 06-13-2008, 01:51 PM
DRACO A5OG's Avatar
Our Pleasure to Assist A Brother Out
'85 Carrera Targa
PCA/POC
Old 06-13-2008, 01:55 PM
Don't push. Only pull.
thought that might be the problem. That's why I said pull on the PASSENGER side.
Old 06-13-2008, 01:56 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
already answered but ill say again. first time i changed mine, both were impossible. used a breaker bar. no problem. didnt have new washers. used the old. no problem. i bought new ones AND new plugs for the 2nd oil change. when i tighten, i tighten down very gently until it stops and then give 1 good medium strength tug on the wrench. there is no need to over tighten them
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 06-13-2008, 03:41 PM
i have similar heat here, upstate NY. i used 10W-30 fully synth. no problems.
1983 911sc
Old 06-13-2008, 03:42 PM
Follow me
seymore's Avatar
I was afraid to go with synthetic because of the leaking issues. But I use it in all my other cars
Old 06-13-2008, 03:45 PM
as far as i can tell, the PO used it for 10 years so i continue. no leaks whatsoever. you can try next time and if it leaks, switch back
some leak, some dont. my car has 100K miles, no engine work ever. no leaks, with the exception of a hose i need to fix
there are some good threads on this site about non-synth vs synth oil. do a search if your bored.
1983 911sc
Old 06-13-2008, 03:54 PM
