Johnb911's Avatar
Blap Blap Blap on decel - 79Sc ROW
Here's the deal.
dual In and Outs
NO cat.
Idles well.after initial warm up of about 2 minutes when it's dead cold.
Always starts right on first crank.
Exhaust doesn't burn my eyes or smell like fuel.
On decel or as soon as I get of the gas a little at all i get a blap blap blap.
I get a bit of a gurgle and a smaller blap f i hold it at around 3000 rpm on the hwy.
hard accel it seems to be fine.
Is this a sign of too rich?
Is this just a sign of a very free flowing exhaust?
Whats up.
Am i paranoid because nothing has gone wrong lately.
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 06-14-2008, 08:47 PM
Max Sluiter
Flieger's Avatar
Cat bypass = more open exhaust = leaner mixture and exhaust
this amplifies the natural "blaps" of CIS on the over-run which cannot be heard normally due to muffers, cats, and airboxes.
CIS= continuous injection system
It keeps pumping fuel even when the throttle is closed according to how much air is passing the metering plate. When you get on the throttle a little, the fuel burns in bursts.
Old 06-14-2008, 09:50 PM
Max Sluiter
Flieger's Avatar
Its normal, though. I would not worry about it too much. Get a check out with an LM-1 air/fuel mixture tester too make sure you will not burn a piston or get detonation or bad stuff like that. This is just a precaution.
Old 06-14-2008, 09:52 PM
Johnb911's Avatar
Flieger,
Thanks that makes sense.
JOHN
79 EURO SC
Old 06-14-2008, 10:52 PM
What the ?
glewis80SC's Avatar
That it what i love about my cat and muffler bypass. My Harley does it too and it has a freeflow exhaust too.
SCWDP 73
1980 SC
Harley Davidson Road King
9/11/01 FDNY/343 Never Forget!
Old 06-15-2008, 12:22 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
my motorcycle does it on deceleration. music to my ears.
ive got a cat bypass but with a stock muffler on my 911 but cant hear the gurgling or pops. hoping when i get a new muffler that i will be able to hear it
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 06-15-2008, 03:56 AM
T77911S's Avatar
check the timing too. retard may do it too.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-16-2008, 05:31 AM
jasonmx5's Avatar
Mine is almost exactly the same set up as yours - SSI heat exchangers with dual in-dual out sport exaust and no cats. Makes exactly the same sound you describe - and I love it
Tried adjusting the mixture and timing up and down, but it is optimal right where I've got it and it always has that little blat-pop decelerating if you come off the throttle quickly at around 3500 rpm.
"Making things easy is hard work"
My current stable: 1991 Carrera 4 Cabriolet, 1992 Mazda Miata, 2004 Lexus RX 330, 1994 F150 4x4 Supercab
Also rans: 1977 Carrera 3.0 (traded for C4 Cab.), 1983 944 (project car - sold)
Old 06-16-2008, 06:50 AM
Designer King
Paulporsche's Avatar
Can someone confirm that in a CIS car this usually means the mixture is too rich, or as Flieger says, too lean. Other posts have stated that intake backfiring is usually a sign of too lean whereas exhaust backfires come from being too rich.
JohnB911,
Have you got any other too rich symptoms, like a hunting idle or a very black tail pipe?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-16-2008, 07:14 AM
RETIRED
Joe Bob's Avatar
Decel popping can ALSO be an exhaust leak and unfortunately head studs.....so if your fix doesn't work check for that.....
2012 ML350 3.0 Turbo Diesel
Old 06-16-2008, 07:30 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
If you havent had your CIS mixture adjusted since the addition of the of the exhaust system, I would encourage you to check with a gas analyzer and make sure your timing is right.
I would hate for you to burn up a piston.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 06-16-2008, 08:40 AM
