Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
Member 911 Anonymous
Hmmm, sounds like what I had. It was my AC Compressor Clutch.
If you have an AC, try taking off the fan & AC belt to see if you hear the noise. It will definitely isolate it. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
When was the last time you did a valve adjust? Perhaps perform another one and take a look at the rockers.
One thing you can do which is extremely effective is get a long handled screw driver and poke it on to bits around where you think it might be - rocker covers, cylinders (underneath), heads, underneath, AC compressor, whatever.
I bet you fairly quickly narrow the source down - to an individual rocker/cylinder/whatever. You stick your ear to the other end of s driver - the handle bit - not the pointy bit. Alan |
Ac compressor is out, so i know its not that.....
You do not have permissi
From the video, it sounds like a non-consistent hammering, possibly metalic.
-The first thought was an exhaust leak (look for carbon around pipes). -Could also be a plug cap that's not fully seated on the plug, and arcing. -Or possibly an intermittently sticking valve or valve spring. On a daily driver (without the external oil sump/radiator), I'd say add a bottle of Rislone or half quart of trans fluid and idle it for 10 minutes before changing the oil, but you don't want that stuff remaining in the Porsche engine. Not sure what is recommended here. To find the suspect cylinder, use an infrared lazer thermometer on each exhaust header to see if they are all burning at the same temp. The cold one will be the culprit.
Meanwhile other things are still happening. |
Thanks John
I was going to take it for an oil change and to fix the oil return tubes but now I find myself not wanting to drive to the shop in case there is an issue
cam chain tensioner?
