Possible Problem at Jacking Point....Need Advice Quickly
1985 Targa......I will be getting new tires in a few days and went to look at where the "welded in pads" are under the car for the 4 point tire shop lift.
So I get under the car and discover 2 things. 1. There are NO welded on pads or pads of any sort in the positions shown on the diagram someone posted with the "X"s. 2. This is where a big issue as I see it has happened. At some point in the cars life, someone jacked the car up probably using a floor jack without the adapter and crushed the tube running just inside the jack point in the in front of the rear wheel on the passenger side. I tried to trace the tube, but the car is so low, I can't get my head under it to see where it goes. There are 3 tubes running the length of the car on the passenger side. I would guess they are oil lines or A/C lines, but I really need to know what the crushed one is, and how serious it is. The car runs fine, which would lead me to believe it is an A/C line, but if it an oil line it needs to be addressed. Like I said, this is the tube closest to the outside of the car, right next to the plug for the jack point. I also need to figure out how the shop is going to put this car on a lift if there are no pads. I could always tell them to use a floor jack with a board for the front and jack the engine seam in the rear, but would rather be able to get a good view under the car. |
1- You can jack on the seams in those areas. They have to be very careful around all the lines (as you discovered) but I regularly put mine up using the welded seams to lift the car.
2- the crushed lines are your oil lines that run from the thermostat (in the front of the rt rear wheel well) up to the oil cooler behind the rt front headlight. In a lot of normal driving, it's nat a showstopper, but it will restrict how much oil gets to the cooler. So on hot summer days with the a/c on, the oil temps will run hotter than normal. Not a critical need, but one that should be addressed for the long-termp health of the engine. Some on here have had success fixing the collapsed area, but in my mind the safest thing to do is replace the lines, and that's not a cheap pair of parts. So mount the new tires and enjoy the car. |
post pic of crushed line
prob. oil line if it is twinned no early cars had pads; use wood blocks and jack away or use the side square receptacles with jack adapter or use motor seam, etc. - many threads on how to jack up be sure to use jack stands - not safe to get under a car on a jack |
No jack pads until '86, sorry.
If the line is visibly deformed, it is an oil cooler line. It should be repaired or replaced soon. Tip: Take your wheels off and deliver them to the tire shop. Don't let them near the car where they can overtorque your lugs or crush more lines. |
There are 3 lines, not 2 and the crushed one is closest to the outside of the car. I will try and get a pic posted. |
Depends on how badly that line is crushed. It's not unusual for the lower oil line to be damaged and so long as it is not pinched closed it may not restrict oil flow.
I have found, with a big Billy Boat front oill cooler, that it is surprising how small an obstruction will seriously restrict oil flow. Don't think that because "it's just a little dent" the oil will readily push its way past it. It's a bit counterintuitive, when you look at it from outside. Maybe somebody who understands fluid dynamics can explain it...
Definitely the oil cooler line.
It is severely pinched and appears to be almost pinched shut. I guess some oil is getting by as I ran the car for several hours the other day with an air temp of around 75-80 and it had 4 bars at speed. I now need to know which line is this one, the return or the feed, so a new one can be found. (Does our host have them?) I circled the line at the relief valve. IT is the one closest to the wheelwell. This looks like a royal PIA to do as it is 1 long line. Does the engine and tank oil need to be drained before the repair is started? I was going to attempt to squeeze it with a channel lock to get it open some, but it looks as though it may crack because it is pinched so much. I have no idea how long it has been like this, since I just got the car. http://forums.pelicanparts.com/uploa...1214412025.jpg http://forums.pelicanparts.com/uploa...1214412098.jpg |
Jerry M '78 SC |
If you do replace the line, be very careful with the threads on the thermostat. When I replaced the line from the thermostat to the tank, I cut the outer bolt with a cutoff tool and then used an air chisel to literally pry the nut off the threads. A little heat from a torch helped as well.
:eek::eek::eek::eek::eek::eek::eek::eek:
Holy Crap!!!!! I just looked on in our hosts parts pages and found that the line is indeed the oil return line from the thermostat to the front mounted cooler. When I clicked on the part and the price came up, I nearly caught a coronary. $400+ :eek: |
worse here as it's an enclosed tube |
there are ways to repair; & aftermkt & used lines you can get... |
Check out www.elephantracing.com to read up on an interesting aftermarket solution for oil lines. They can be purchased here at Pelican also. |
What do you guys torque your lugs to?
Steve |
Here's a thought I had...................
Is that return line under any type of high pressure? Because if it is not, I was thinking that it would be totally feasible to cut out a small section of the line, get rubber fuel line (or high pressure line), slip it over each end and clamp it down. Since it is just a return line, I would think that method would be fine, no? |
| All times are GMT -8. The time now is 09:11 PM. |
