OldTee's Avatar
87 Carrera DME failure?
Today a very good mechanic told me my DME was not working. Said something about 5v not where it should be at the 02 sensor. He could not get the mixture to behave. The car runs, but not as smoothly as I think it should. Before I buy a new (ugh and not going to happen) or a used or rebuilt unit, what home tests can I do to reboot the damn thing. Kicking my PC seems to work sometimes, what about this thing?
Any luck opening and re soldering things inside?
Who rebuilds these things? What about swapping? Any advice of used via Parts Heaven or DC Auto vs. a rebuilt unit?
Old Tee
all 911s sold
Old 10-02-2007, 03:54 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Whoa!
The DME or the DME Relay?
I'd say first check the CHTS to see if you got the single wire or upgraded double wire.
or get a new DME relay and replace it, you know you need a spare anyways. You can take the DME relay apart and re-solder it but it's only $30, just MHO.
Do a search on CHT and you will see what it looks like.
'85 Carrera Targa
PCA/POC
Old 10-02-2007, 04:04 PM
S ECU Repair's Avatar
Hello, rebuild Porsche 3.2 carrera units .IM for more details
Old 10-02-2007, 04:06 PM
Here's a very nice write up on the Relay, failure and repair (credit to Steve Wong). You might as well get a new one as a spare in any case. http://www.911chips.com/dmerelay.html
Here's a DME Tech article with a section on Cracked Solder Joints: http://www.pelicanparts.com/bmw/techarticles/E36-DME-Repair/E36-DME-Repair.htm
Warren & Ron, may you rest in Peace.
Old 10-02-2007, 04:14 PM
DRACO A5OG's Avatar
Nice Reply
'85 Carrera Targa
PCA/POC
Old 10-02-2007, 04:18 PM
OldTee's Avatar
Originally Posted by DRACO A5OG View Post
Whoa!
DME. Relay is OK.
Old Tee
all 911s sold
Old 10-02-2007, 05:17 PM
OldTee's Avatar
What does .IM mean?
Old Tee
all 911s sold
Old 10-02-2007, 05:18 PM
OldTee's Avatar
Good lead. Thanks.
Old Tee
all 911s sold
Old 10-02-2007, 05:24 PM
Instant Message .Click over my name to send a private message
i just had a DME failure on my 87 a few weeks back. After hours of testing and learning about my car, I swapped out DME's with another nice Plelican and it cranked right up. Took me about 30 minutes to reflow the cracked soldier joint and I was back on the road.
Old 10-02-2007, 07:07 PM
Lorenfb's Avatar
If you require a rebuilt DME ECM, call Wayne/John at Pelican Parts!
Many seem to forget that Pelican Parts has many sources for new or rebuilt parts.
Why use a questionable source/DIY effort for such a key component, when Pelican Parts is here?
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-02-2007, 07:50 PM
Wash. State
nesslar's Avatar
Thumbs up
Yeah!
Old 10-02-2007, 08:03 PM
Make Bruins Great Again
Por_sha911's Avatar
Hey Loren, do you still do the DME ECM rebuilds for Pelican? (Not that its a bad thing)
Joe
Old 10-04-2007, 05:17 PM
OldTee's Avatar
Update. Took my computer over to a friend and hooked it up to his 87 Carrera. His car ran exactly the same with my computer as with his. Not sure what to do at this point. The car has a new O2 sensor and not a cheap one either. How do you check the operation of the O2 sensor. Any ideas?
Old Tee
all 911s sold
Old 10-04-2007, 05:54 PM
I have a spare new 02 sensor if you want to test with it, Old Tee.
I can get it to Michael or someone on your side of the river, and you can get it from there, perhaps.
What makes you think it is DME or possibly 02 sensor?
Any chance it is one of the other sensors?
Emery
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 10-04-2007, 07:04 PM
DRACO A5OG's Avatar
Acoording to the Bentley Manual, use a digial multimeter and test the #2 & #3 connections in the harness located in the engine compartment.
With the engine on it should read 12Volts
If it checks OK then it directs you to the DME relay post 87B
'85 Carrera Targa
PCA/POC
Old 10-04-2007, 08:28 PM
I'm not sure what your saying here. Do you mean your friend's 87 runs like your car did with your ECU?
BTW, A generic Bosch sensor is going to perform like a Plug-n-play unit. The only difference is the connector on the harness. Perhaps he has a wideband counterpart for other reasons?
Old 10-04-2007, 08:43 PM
OldTee's Avatar
Thanks to all. Have been traveling.
To answer above question. No, his car ran with my computer like his car ran with his computer. No change.
s5uewf:
Watch Dorkiphus. I may take you up on your offer.
Right now I really need a loaner computer to use on the car to do some tests. Will check he O2 sensor as above next.
Thanks.
Old Tee
all 911s sold
Old 10-11-2007, 10:14 AM
Thanks.
OldTee; I may need to test my son's '88 911 computer in someones car...depending on how other tests go this weekend. I'm in Carroll County. Would you or anyone you know be able to try my (son's) computer in your car?
Mike Pate
baby sitting '88 911 Commemorative Edition (60k miles) for son in Baghdad
Old 07-01-2008, 08:25 AM
