mack6820's Avatar
when does your low fuel light come on?
Hey guys. I installed the white gauge faces and now I believe my fuel gauge is off. My low fuel light comes on at approx 1/3 of a tank. I think the fuel is actually lower than it shows on the gauge now.
So, When does your fuel light come on?
Certified Southern Dumbass!
83 911SC with 993 conversion,
98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Old 06-27-2008, 03:31 PM
gtc gtc is offline
abides.
gtc's Avatar
FWIW, mine comes on very late... right near the empty tick mark. Definately depends on the car though, as I know some people who's lights come on closer to 1/8th of a tank.
I'd be curious to know how it works.
Graham
1984 Carrera Targa
Old 06-27-2008, 04:58 PM
rnln's Avatar
very low for me, almost empty.
Fat butt 911, 1987
Old 06-27-2008, 05:01 PM
mack6820's Avatar
With a full tank, does yours show full or beyond the full mark?
Old 06-27-2008, 05:08 PM
Peter Zimmermann's Avatar
My '82 has about 2 gallons left when the light flicks on steady.
Your sending unit is very easy to remove - lift the carpet away at the left rear corner of the tank (near the brake booster) and locate the sender. Pull it out (remove 5 nuts/screws) and check if the float is moving smoothly inside the tube. ALWAYS trust the light if it comes down to light vs gauge!
Keep the Shiny Side UP!
Pete Z.
Old 06-27-2008, 05:15 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-27-2008, 05:26 PM
abit off center
cgarr's Avatar
Hard left turn with a half a tank and its on.
______________________
Craig
G2Performance
Old 06-27-2008, 05:42 PM
Member 911 Anonymous
DRACO A5OG's Avatar
2 gallons
'85 Carrera Targa
PCA/POC
Old 06-27-2008, 05:44 PM
beasty's Avatar
mine comes on when its super low
'14 Cayenne GTS
'04 996 Coupe
'02 C4S Coupe
'99 M Coupe
'84 M491 Coupe
Old 06-27-2008, 05:46 PM
911longhorn's Avatar
wouldn't attempt to go more than another 30 miles when mine comes on
1989 Carrera
Hookem Horns!
Old 06-27-2008, 08:35 PM
Detached Member
Hugh R's Avatar
+1 about 2 gallons left. My car runs out of gas just a hair above the E, ask me how I know.
Hugh
Old 06-27-2008, 08:51 PM
Air Medal or two
afterburn 549's Avatar
At about 16 lbs left in it I guess
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 06-27-2008, 09:04 PM
I use the upgrade thick rubber gasket insted of the paper one. The unit now sits higher.
I tested it at 2 gallons with paper. Haven't even had the light on with the rubber.
Anyway it's 2 +
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-27-2008, 09:05 PM
Originally Posted by DRACO A5OG View Post
2 gallons
Mine comes on a little before that. I usually wait for the light or 400 miles to fill up if I'm DD'ing.
My gauge is hit and miss, it'll hang up at 2/3 tank sometimes, sometimes lower. But the light always works.
Luckily, we have gas coupons and don't pay this much...but just think if you paid this much for gas. But this is about 10 miles after the light came on.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 06-27-2008, 10:59 PM
slodave's Avatar
Mine doesn't. I have cleaned the sender, but nothing. I haven't had a fully working gauge, well, ever. I only know when I am full.
Old 06-27-2008, 11:05 PM
dshepp806's Avatar
I never let mine get anywhere near low enough for the light to come on..flickered once, in the early days of ownership,..never again...
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-28-2008, 03:09 AM
Jim Williams's Avatar
Based on how the sending unit works (reference Pete's photos), once the light comes on, the gauge can't read any lower.
Think of it this way: The float with the metal disk on it's base, which turns on the light, also carries the slider which varies the resistance of the sending element which determines the position of the needle on the gauge. So when the float reaches bottom, the light turns on, and gauge can't read any lower.
Does anyone have a fuel gauge where the needle on the gauge continues to drop after the light comes on?
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 06-28-2008, 04:25 AM
Mine comes on "right" before I'm SOL (by a FAR less margin for error than any car I've ever owned)...taught me a lesson in the early days of ownership .
mack6820's Avatar
Thanks for the replies guys. I know the sending unit is good, I just need to adjust the needle on my gauge. This all started when I switched to the white gauge faces and removed the gauge needles.
Old 06-28-2008, 08:30 AM
About 2 gals.
Old 06-28-2008, 12:15 PM
