s caliper rebuild help needed
Bought some S calipers and took them a part for new seals. Really very clean and didn't need seals but put them in, lubed them and tried putting the pistons back in. No go. The pistons are getting stuck on the needle that inserts into the back of the piston. Was I suppose to take this off the back of the piston and clean it or something? The rubber inside this piece is broken on both pistons? Feels like an air lock as you push the piston in and it is spongy and will not go further. I took the piston seal out to confirm it is the needle causing the problem. Never had this happen before...any help appreciated.
Thanks Steve |
The knock-back mechanism always seems sticky. Lots of posts on this subject if you search. Be sure the caliper is vented of course. A C-clamp properly used works well.
There should be no rubber in the knock-back mechanism.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Max Sluiter
Contact Eric Shea at PMB Performance with any questions about brakes, especially Aluminum S caliper rebuilds.
Member "Eric_Shea" here on Pelican. A sample of his work:
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Thanks guys, the responses help. My pistons are too rusty to reuse so I will order some new ones. The knock back springs are really stiff going over the needle. I have taken them off the pistons and will clean them really well before putting them on the new pistons. I also plan on using the Porsche paste for reassembly which I hope will make the knock back springs slip on easier. Will see about that?
Steve 91 964 turbo 81 ROW 911SC 11 997.2 |
AutoBahned
yes the porsche paste is the best - Bill V. has posted on it if yo need a p/n
you know aobut the stainless steel pistons for the S calipers...? |
Yes, just ordered a set yesterday as 3 of the 4 of mine had too many pits to trust on a race track! Thanks
