Auxillary Oil Cooler ?
At what temperature is the fenderwell mounted thermostat supposed to open and allow oil to flow to the front fender mounted oil cooler?
What actual temp on the gauge with temp readings, and what line on the idiot gauge with lines?
1985 Carrera Targa in the fastest color......Black........Growing list of goodies now includes SW Chip, M&K premuffler, Sport muffler, DME update, etc. |
The thermostat should be all the way open by 190 degrees.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Reason I ask is that I have a crushed return line and have no idea if oil is getting past the crush or not. The car sure does not run hot, but I would like to know if oil is actually running through that line. It will get changed out after the season either way, but it would be nice to know.
Administrator
Is it hot to the touch after a long drive?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
To add to Stveve's info, the aux t-stat for the front circuit starts to open @113*F
I believe that these are the Carrera temp scales
As for feeling the oil line, every time I say I am going to do it after a run, I forget. ![]() 3 things I will be doing................ 1. Touch the lines after a run to check for hot oil running through them. 2. Replace return line over the winter. 3. Replace my stupid lined gauge with a degree marked one. (I know there is a place that does this, but can't remember who. If someone has the link, please post it)
Cigars and 911's -- Smile
Someone may need to confirm.
The numbered guage requires a different sender, both are available by our host. Do an easy search.
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
The old numbered Gauge needs a different sender, but N. Hollywood can just redo the face
Anyone ever get work done by BigMarks?
+1 for Hollywood Speedo. They just did a couple for me. I believe I spoke with Valdek (sp)?. Very nice guy.
Jon |
What's up with that? Did you just have the faces redone or did they do an overhaul? Why would the guy tell me they overhaul the whole thing? Things that make you go, Hmmmmmmmmm.
They replace the temp guage with a VDO unit, silk-scrren the face, and provide a new sender. The old numerical temp kit is NLA. At least, I couldn't find it, so I called NHS. It was quick and easy.
Jon |
Makes you wonder why they can't just redo existing units face.
When I brought my C3 over from Germany they just redid the face to change from Km. to Mi., They even rolled the odometer to the correct mi equivalent and provided a certifiction document of the changes.
abit off center
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Exactly my point. My Carrera has a VDO gauge. Druck pressure on the right, oil temp on the laft with hash marks. What would be so hard to silkscreen a new face to keep the druck on the right and replace the 4 hash marks on the left with a number of lines and numerical readings? Why does the unit innards need to be changed? I am having a hard time understanding why this is so hard to do. Just like this, but in the original black face with white numbers.
