Wheel HP of a stock 3.2
Just wondering what is the stock wheel hp of a 3.2. I have a stock 3.0 that gets about 180hp at the wheel. I am considering putting a stock 3.2 on the the car but I don't know what a stock 3.2 dyno's at the wheel??? I know this is not exact and there are lots of different dyno results. Just curious what you have experienced.
82SC Track Car |
I am no expert on dyno numbers, but I believe 180 HP at the wheels would calculate out to approximately 207 at the flywheel.
Is there a need to change out your 3.0? It would appear it is healthy and making good HP. Mike |
Yes I am in a race class that 200 - 210 may be optimum but may be not.
82SC Track Car |
You might want to find a RoW 3.2 as it had 231hp stock. Accounting for drivetrain loss of 15%, you get 197whp. A little tweaking with the exhaust and ecu and you'll have a "stock" 3.2 with what you're looking for.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
My car is stock. Came from Canada. Not ROW as far as I know.
Gets 201/202 at the wheels, a touch less if temps are hot.
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
some dyno sheets in this thread from my 87. At some point the 3.2L went from 207 to 217 hp. I think it was just a chip change. Maybe when they went from 24 pin to 28? Anyway, the 87 was rated at 217hp and dyno #'s were close to that factoring in 15% loss to the wheels.
More kudos for Steve W and dyno sheets
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
My stock '88 put down 204hp @ 6k rpm when I had her on the dyno a few weeks ago.
Carrera 3.2 - "Faster, Stronger, Better" |
I have read many threads about putting carbs on a CIS motor and it seemed as though the cost was almost high as an engine swap after you sell your old motor. With the 3.2 you get Motronic fuel injection which would be nice.
82SC Track Car Last edited by cay-ahe; 07-14-2008 at 05:24 AM.. |
MBruns for President
You can't really compare dyno's some are more optimistic than others.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Right, but I am just looking at ball park numbers to get a feel where the 3.2 comes in. It may be too much power for what I'm trying to do.
I did just look at the Bitz Racing info and this might be my best approach at this point. It looks like I could Dyno tune and pretty much get the advantage of EFI and the control of a range of performance. I had not even considered this possibility. I need to research this option further.
82SC Track Car |
UFLYICU
One thing to consider is that your 3.0 has larger rod bolts. The 3.2's used smaller rod bolts that should be replaced with racing rod bolts if you spin the motor beyond the stock limiter. I replaced mine even though I'm not spinning the motor much higher. I just wanted the added protection. If I were you, I would just throw some carbs on that 3.0 and go racing. I race with 3.2's and 3.0's, and the 3.0's are out front.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
My stock 3.2 with megasquirt, ssi's, and M&K 2 in/out showed 241 at the wheels on our dyno-jet. That was with some optimizing of the spark and fuel tables but still in the safe range. We also did a coast down and showed right at 12% drivetrain loss.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
My Carrera 3.2 w chip and cat bypass has gotten from 211 to 217 rwhp depending on the day and run.
Some ideas. For a lighter rear end, a 2.7-2.9 built on a mag case, high compression, w E - C2 cams. A 3.0 with small ports, cam timed for tq, higher compression, 1.5" long tube headers, carbs or mfi. A 3.2 w the cams re- timed for torque, a custom chip, and 1.5" long tube headers might be tuned to get the most out of the low end and not over shot things. A 3.6 with a restrictor plate for a big fat low end. |
82SC Track Car |
