19 years and 17k posts...
Henderson Glass replaced my windshield last April and they did a great job. I sipplied a new windshield gasket (from our host) and they said it made the job much easier. Perfect replacement, no problems , all for less than $300,
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Shane - 1984 928S |
anyone know a good place in Nashville, Memphis or inbetween?
Shane - 1984 928S |
Blackbird Pilot
Sorry to hear your bad luck...the problems i've heard of are the bottom edges of the windshield not sealing properly causing a leaky seal. The shop doing my car had their guy do the install, its tricky but if the installer isn't lazy it can be done correctly.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us |
I did my own last fall - wasn't hard at all... had a friend come over to help apply pressure to the outside as I pulled the cords inside. Took about 10min to get it in, and amazingly, no more leaks! I put in a new seal from Pelican at the time, and bought the real sigla oem glass at parts heaven. The advantage to doing it yourself is, you know that it's done right. I didn't use any sealant and adjusted the trim by tapping with a wood block and rubber mallet as described in the great threads here on pelican. I was scared at first, but I'd do it again in a heartbeat. You should be able to convince a local windshield shop to sell you the glass. My original glass did crack as I was pushing it out from the inside, but I think you could get it out easily if you're careful.
Ellsworth Wente 87' 911 Targa 09' Cayman S 48' Lincoln Continental |
Update:
The company sent the Manager with 20 years experience. He tried 4 times and was unable to get the windshield in. He says the dash was hitting the glass. I raised the cap, trimed the foam and screwed the cap back down after he left. He is due to return tomorow with his crew. I was tempted to buy the glass and try myself but the company offers a lifetime warranty on their work.
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Super Moderator
I'll second any votes for Safe-lite. Quick, reasonable, and professional.
Update:
The company sent the Manager and a installer. They had it in in ten minutes. DONE!
I did it for the first time on Friday. Soaped up the window frame lip with dish soap, wrapped a piece of twine in the groove and ten minutes later it was in. Of course I had a friend there to apply pressure to the glass from the outside.
I think it took me more time to clean the glass afterwards than it did to install it.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
