sudo apt-get purge 930
equality72521's Avatar
I think my internal T-stat may be backwards
Does anyone have detailed pics of how it goes in? I'm seeing higher oil temps since putting the engine back in. Was running about 210F and now is around 240F. The front oil lines are hot as hell so I know it's not the external one. I was questioning myself when I replaced the o-ring on the internal one and was re-installing it.
--clutch-monkey
Old 07-25-2008, 11:49 AM
304065's Avatar
The bolts are "clocked" it only goes in one way
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-25-2008, 11:50 AM
resident samsquamch
sand_man's Avatar
Yep. Your ignition timing change? What about AFRs?
-jeff
Old 07-25-2008, 12:11 PM
Whew! Thanks, I didn't know that. My AFR's are are about 11.7 under full boost. Timing checked good but I'll check it again because I've been known to accidentally have the dial turned slightly on my timing light. Now that I know the stat is right rechecking the timing is the next step.
--clutch-monkey
Old 07-25-2008, 12:16 PM
Friend of Warren
I can't tell you how many times I have done that. I wish the dial advance wasn't so easy to turn!
Kurt V
Old 07-25-2008, 12:27 PM
DSPTurtle's Avatar
+1 My Craftsman timing light advance knob seems to have a life of its own!!!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-25-2008, 02:33 PM
The dial should have detentes that click for each degree of advance. BTW, my timing was off. I set it correctly and my exhaust gas temps went way down too.
--clutch-monkey
Old 07-25-2008, 03:43 PM
DSPTurtle's Avatar
That was a nice easy fix... good for you!!!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-25-2008, 04:03 PM
Well, I thought it was fixed. Went to Porsches2Oxford today and even though the temps were mild and I wasn't driving hard the oil temps were still approaching 230F. Any other ideas? I did install a new oil temp sensor while the engine was out so maybe I was reading low before and now I'm reading correctly. The question then is why am I running so warm? Any ideas?
--clutch-monkey
Old 07-26-2008, 03:34 PM
