Which 915 trans for 1986
I got a rolling tub, need a 915 trans. What years/models will bolt in?
Any bad years to avoid? Thanks, Skip |
try to get a euro 915/72 with cooler.
carrera coupe 85 |
Theoretically, any 915 will work. A 915 that came out of an '84-'86 car will have the notch in the housing needed to clear the speed and reference sensors, though. You may also want to get a '76 or later 915 with the electric speedo hookup. I'm not sure what axles you're using, but the output flanges on the 915 might (?) be different depending on the particular 915.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
'86 US/Cdn/J.FRG-M298 used a 915/73, RoW used915/72(mit cooler)
Any of the 915s w/ e-speedos from '76 915/44 can be used
Crotchety Old Bastard
The gearing varies per application. Bill has the charts.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
1977 915 for a 1986 911
I found a 1977 915 locally. Other than turning the axle flanges, draining the oil and looking at the magnet, what should I do to check it out? How do you sequence through the shifter with a pair of vice grips?
Is this a "bolt-in" for my 1986? I did not look at it yet but I understand from this list it should have the electric speedo output. What does this look like, is it a box or is it just a connector on the housing, or? Any compatability issues? Thanks, Skip |
gearhead
That year had likely still got course spline output flanges on it. This shouldn't really be a problem if you want to use large "turbo" style CV axles on it. This assumes you will be buying CV's. If you already have CV's with the car, then your bolt pattern to the flanges will be wrong and you will either need to replace the differential and output flanges on that tranny OR you will need to buy CV's. Did that make sense?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Immature Member
These are the sensor notches for the later Carrera bellhousings:
![]() And this is the electronic speedo sensor on the side of the tranny: ![]() In the 'BTDT' dept, get as late a model (84-86) as you can find so you don't have to cut out those notches yourself or swap in a different differential housing. I also found out that in '85 or '86 Porsche updated the bores in the diff housing to reduce pounding and loosening of the bearings.
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
