East Coast R Gruppe
Turn Signals don't work
I have a 1982 911SC that my turn signals stopped working.
No light in the dash nor in the rear or front siganls. Fuse or turn signal stalk? Any suggestions on how or what to check first? Thanks,
OGRP3 RGRPNE |
Check fuses first, then all connections to stalk. Also, move the turn indicator lever to either right or left position with the ignition off, this should turn on the European parking light for that particular side. Does it work? If not, that just confirms you are getting no power to the system. Problem could still be the stalk, but more likely a power source.
Check the turn signal relay. See if its seated properly. Try the hazard lights--do they work? They use the relay also. If the hazards are dead, then it again looks like a power supply issue. Keep us posted
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 08-06-2008 at 07:29 AM.. |
East Coast R Gruppe
Will do and will let you know
OGRP3 RGRPNE |
East Coast R Gruppe
"Check fuses first, then all connections to stalk. Also, move the turn indicator lever to either right or left position with the ignition off, this should turn on the European parking light for that particular side. Does it work? If not, that just confirms you are getting no power to the system. Problem could still be the stalk, but more likely a power source.
Check the turn signal relay. See if its seated properly. Try the hazard lights--do they work? They use the relay also. If the hazards are dead, then it again looks like a power supply issue." 1)Turned the indicator lever right and left and the European parking lights DO work. 2) Hazards do not work. does this narrow it down to a power source or stalk?
OGRP3 RGRPNE |
I think I'd go with the flasher .
Silver 1980SC Euro coupe |
East Coast R Gruppe
Flasher being the stalk?
OGRP3 RGRPNE |
RS 73
Flasher is the little thing that turns them on and off. Like a relay that cycles. Try replacing that.
Dick Lague RGruppe #79 1973 RS Spec Carrera 2001 Saab 95 Aero 2003 Saab 95 Aero |
Flasher is the relay. Located in the trunk, under the cowel, just in front of the fuel gauge. It's the square/cube shaped one.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
East Coast R Gruppe
Ossiblue, thanks,
weird I drove the car this afternoon and both are now working. Seems they cut out after i drive for awhile. I will replace the flasher and see if that solves the proble.
OGRP3 RGRPNE |
BTW, now that you know where the relay is, you may try to wiggle it in the socket to insure it is properly seated and making contact. This could be the problem rather than the relay itself.
abit off center
If your old you don't use them anyhow!
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
This was a very helpful thread! I also have a 1982 and it is a very hot Day in Washington DC and like the man said, ALL of a SUDDEN they stopped working!
My Question is, even with the heat is the problem the Flasher unit that is Border line bad and the heat sends it over the line?
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si |
