plymouthcolt's Avatar
Do I need an inch lb torque wrench?
This was a spur of the moment purchase from Sears.com on fathers day weekend and it was on sale for $131. http://www.sears.com/shc/s/p_10153_12605_00934186000P?keyword=00934186&sLevel=0
I've been debating on keeping or returning it, so other than valve covers, I see no other need for this wrench.
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 06-22-2008, 12:22 PM
York's Avatar
I purchased one 6 months ago, use it for spark plugs, valve covers and recently to re-torque the intake manifold on the 911. It is also handy for my other car, moto and bicycle. I think that you will find more uses for it if you keep it.
'86 911 Sunroof Coupe
'91 Miata
'77 BMW R75/7
Old 06-22-2008, 01:17 PM
I have one. I think I've used it twice in the last five years.
Richard
Old 06-22-2008, 01:29 PM
abit off center
cgarr's Avatar
The American way is to use it then return it!!
______________________
Craig
G2Performance
Old 06-22-2008, 01:40 PM
Grappler
Rodsrsr's Avatar
No
Old 06-22-2008, 01:41 PM
Peter Zimmermann's Avatar
I use mine for...drum roll please...setting differential bearing pre-load. The 3/8" drive torque wrench does everything else - by the way, rocker (valve) cover nylok nuts torque to 18 lb/ft - perfect application for a good 3/8 wrench... So the answer is, as Rodsrsr stated - no.
Keep the Shiny Side UP!
Pete Z.
Old 06-22-2008, 01:55 PM
dshepp806's Avatar
Pete,
18 for the VC nylocks?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-22-2008, 04:20 PM
York's Avatar
I think that is 6 ft-lb (8 Nm) for the valve cover nuts.
'91 Miata
'77 BMW R75/7
Old 06-22-2008, 04:40 PM
Yep...I use a Park bicycle torque wrench that's calibrated in inch/lbs for these (around $40).
Old 06-22-2008, 05:38 PM
KTL KTL is online now
Schleprock
KTL's Avatar
I use mine all the time for M8 fasteners, since my "big torque wrench goes from 20-150 ft-lb and my old school beam wrench isn't always convenient to try and read the pointer whilst leaning on the wrench (and trying to lean on it properly). I say keep it if you're a torque spec. nut. If close enough is good enough, then take it back.
Kevin L
'86 Carrera "Larry"
Old 06-22-2008, 06:29 PM
These are great for brake caliper bleeder nipples.
Old 06-22-2008, 08:13 PM
30-150 in lbs. = 2.5 - 12.5 ft lbs.
Extreme accuracy when tightening small fasteners.
"These are great for brake caliper bleeder nipples."
... and electrical ground screws.
No. For the few times you will actually need one, purchase a beam type in.lb. torque wrench. Much cheaper and more accurate over its lifetime. There's a better chance of damaging smallish threaded fasteners if this click-type loses its accuracy.
Sherwood
Old 06-22-2008, 08:57 PM
Originally Posted by 911pcars View Post
...For the few times you will actually need one, purchase a beam type in.lb. torque wrench. Much cheaper and more accurate over its lifetime....
That's what my Park is (beam type)...perfect for my limited applications...
Old 06-23-2008, 03:47 AM
I have used mine a couple of times over the past couple of years.
Mike
Old 06-23-2008, 07:30 AM
Originally Posted by dshepp806 View Post
Pete,
Doyle
Back in the day (let's call that the early '80s) I had already been a P-car repair shop owner for a number of years. My mechanics and I used to take a mid-morning coffee break, sit in a corner of the office and bat things around. 911 service and repair had become about 90% of our workload, and many items on those cars were tightened by feel due to sparse available torque info from the factory. We used rule of thumb guidelines that were, roughly; 8mm hardware = 18 lb/ft, 10mm hardware = 35 lb/ft, 12mm hardware = 65 lb/ft, and 6mm hardware was sensibly snug. Of course, special items like CV bolts, drain plugs, spark plugs, ball joints, etc. all had specs readily available. Porsche always wrote their manuals for technicians with some level of experience, and their "Spec" books were similar. Service instructions for many parts assumed that the mechanic already knew what the spec was and didn't feel a need to include it.
We made a collective decision, during a morning break, to try to assign a torque spec to virtually every fastener. At the time we had not torqued rocker (valve) covers; tight was tight and they involved two types of gaskets - cork and other. Cork gaskets required a very light hand, otherwise they would be squeezed out from between the cover and cam housing. The "other" gaskets ranged from paper products through to contemporary super gaskets. They were far more firm than earlier cork versions, therefore we knew they could handle more torque. As time passed we practiced, and we also used the '78-81 and '82/83 Spec books for reference. I quote from either, "All M8 bolts (meaning bolts, nuts, studs) on crankcase and camshaft housing - torque = 2.5 kpm (18 lb/ft)". Confusion entered the picture for the first time inside the early SC Spec book, where it also states, "Cover to camshaft housing - torque = .8 kpm (6 lb/ft)". We went hmmmm, and started torquing valve covers, because we wanted to learn if a typo existed along with a language glitch (those do exist in P-car manuals), perhaps meaning that the hardware was M6, not M8, and the cover was for the chain housing not the cam housing, or if Porsche was finally telling us what the rocker cover torque using cork gaskets really was. Well, we had already moved on to later gaskets, but tried the 6 lb/ft number on early cars that still had, mostly, warped magnesium covers that we used the cork version on. We discovered that the 6 lb/ft number was pretty good, perhaps a little light, but OK. We did a few cars with aluminum covers and next generation gaskets, tightened the nuts normally, by hand, and found that we had been tightening cover nuts to about 16-17 lb/ft after following up with a torque wrench. We did a few cars at 18 lb/ft, based on the rule of thumb, plus the fact that 8mm crankcase hardware was exactly the same as rocker cover hardware, and its torque spec was, you guessed it, 18 lb/ft. Not long after that we made another interesting discovery; there are two types of 8mm aluminum flat washers being sold out there. One has a somewhat shiny, silvery finish - they are junk and will crush into the stud threads at 18 lb/ft. The other 8mm washer has a dull gray finish, is available from the P-car dealer, and high-quality gasket kit makers such as Wrightwood Racing. Those washers do not crush, and can actually take more than 21-22 lb/ft of torque; and they are the exact washer that's used on crankcase halves on the lower end of engines.
In case that you think that I pulled the 18 lb/ft spec out of some dark place, I did not. The spec came from a well thought out, logical process - my shop, using 18 lb/ft, never had a stud or nut strip or leak, and this was on as many as ten 911s in a week, over a period of almost twenty years. I rest my case.
Pete Z.
Old 06-23-2008, 01:22 PM
2002 996 C4S
jcsjcs's Avatar
Along these lines - what about the guidelines for the fan belt - my manual says 35 ft. lbs - yet I can seem to get that high using the Fan Belt Pulley Tool.
I know that the gap between the pulleys sets the tension on the belt - but am I weak or is 35 ft. lbs a tough objective? (Or do I have the ft. lbs wrong???)
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 06-23-2008, 01:49 PM
Schleprock
KTL's Avatar
Yes it's very easy to reach 30 lb-ft with the pulley spanner and 24mm socket wrench from the toolkit. If somebody wanted to muscle-up on tightening the fan nut, he could easily do so.
I think the spec book for my car says 40 Nm which equals ~31 lb-ft. So you are plenty tight with 35. Just be sure to recheck after installing a new belt. It's easy to install the pulley a little crooked. Once the belt and pulley "settle-in" with some running, you need to recheck the belt tension.
Kevin L
'86 Carrera "Larry"
Old 06-23-2008, 01:58 PM
Porsche 911 SC, SAAB SPG
I mostly use mine when rebuilding gokart or lawn mower engines.
However there have been a couple of occasions that I have used it on the Porsche engine and some M8 bolts.
Mine reads in inch/lbs and newton/meters so I can use the Bentley specs without having to convert from ft/lbs to inch/lbs.
Jeff C
Old 06-23-2008, 02:03 PM
Komenda Fan's Avatar
Peter - it's great having you here!
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 06-23-2008, 02:08 PM
dshepp806's Avatar
Great read, Pete. Your case is "rested" (if need be). Hell, that's 10,400 Porsches! Who the frick would argue with that (not me),
........discuss,..yes.
I did note in my past readings that M8's were around 17 ft-lbs,..but read other stuff that mentioned VC nuts were not considered a "fastener" (neccessarily). I just keep reading ,..knowing that a holostic approach will do...(of course, listening to the P-wrenches).
Yes,.I've heard of these "other" washers;;;;;;too.
When I think of what could be the "variable" here ( for so many different ranges of VC torque , almost 3X the range) ,it has to be the covers, no? ((((understanding that the torque should be evenly applied across the V/cover.)))))) I guess , for the SAME gasket material, an evenly applied torque at the lower value would do as well as an evenly applied torque value (at the M8 fastener value) insofar as oil leaks........fine. Iwould imagine you'd see a LOT of different condition VCs on THAT many 911's.
As to VC trueness.......I guess one needs to be very careful when spreading the torque across the VC's, so as to NOT bend the VC's in spots..
Pete, did you guys check EVERY VC for trueness? Or only when the problem presented?
Just trying to learn here,..and nothing better than getting the take on these things from someone FAR removed from the "shade of the tree"........ (pro).
Thanks!
My best,
Doyle
Middle Georgia
Old 06-23-2008, 02:13 PM
