What is this piece?
Hi there.. i am looking to replace this oil line, because i found that when accelerating, there is oil leaking from this line, and i don't know the piece number to replace it, or if i can use another OEM to replace it.
It's the metal (gold color) that come from cyl 1 at the block (i think). Here is a pic of it (circled in red): ![]() thanksss
911 T 2.4 (MFI) 1973 with 911 E fuel pump from 1971 The beatiful Buenos Aires, Argentina! |
It appears the PO installed oil-fed chain tensioners. If so, that's the thin oil feed line leading to the tensioner. There's a similar oil line on the right side of the engine.
A later upgrade added some brackets to reduce the line from vibrating and failing. After replacing the leaking line, install the support brackets. Pelican has these parts. Sherwood |
thanks sherwood, can you help me with the pieces i am making a big shop from pelican, but because my technical english is not so good, i don't know well the pieces name..
thanks!!
it's called a Tensioner Oil Line, found on a 1984 carrera to 1989 model year. Left or right, in this case, it is a left line.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
but mine is a 1973 MFI, that tensioner oil line fit's in the same place, and it's the upgrade??
do i need another piece for it?? thanks!
Yes, you have the upgraded, oil-fed Carrera-style tensioners. It appears from your picture that whoever did the work did not use the necessary support brackets and clamps for those auxiliary oil lines. When you order your oil line, include:
1x left bracket 1x right bracket 2x clamps 2x clamp screws (bolts) When the supports are not used the auxiliary lines can crack, which must be what happened to you.
Keep the Shiny Side UP! Pete Z. |
This is what it looks like on an 1987 3.2 liter engine. Not sure this will help. The leak is from the rubber transition piece in the middle of the picture, not the smaller chain tensioner lube line directly to the left. Look closely at this smaller chain tensioner lube line and you will see how it is held in place with bracket and rubber collar.
1987 Carrera 3.2 Last edited by sig_a; 08-11-2008 at 04:35 AM.. |
1x left bracket --> 930-107-341-00-M260 1x right bracket --> 930-107-342-01-M260 2x clamps --> 999-511-174-02-M260 2x clamp screws (bolts) --> 900-119-059-02-OEM and this are the lines?? left line (the one i have leaking) --> 930-107-347-02-M20 right line --> 930-107-348-09-M20 should i also buy this ones and change the ones i have? (i mean essential ones, because of money.. :S): left pressure-fed cam --> 930-107-347-10-M20 right pressure-fed cam --> 930-107-348-11-M20 checking with sig_a picture, the new oil line, is different from one i have, and i don't think if it will fit or if my original line has been changed by previous owner, and i don't have the right one. mine has a curve and goes under pointing to the right, and this one, goes across to the left, in different position...
pszemia
"mine has a curve and goes under pointing to the right, and this one, goes across to the left, in different position..." __________________ The main line, pictured with the wrench, is completely disconnected at the other end. I was in the process of removing and replacing it. The new line was reconnected where the wrench is pictured, and at the other end where the gold colored female threaded fitting is located. Look closely at the upper left hand corner of the photo. The fitting point I'm referencing is adjacent to the lower corner of the valve cover nut. You can see easily see the fitting's open end and female threads against oily black background. The smaller line you are thinking about buying the bracket for connects to the "inline tee" just to the left of the leaking rubber transition on the main line.
1987 Carrera 3.2 |
pszemia:
Not sure you can modify your 2.4 liter 1973 911T with parts designed to fit 1984 - 1989 Carrera. Perhaps someone here can chime in and give you better info. But if you can make the complete modification, you will need the following parts to add to your list: 900 123 115 30 OEM, N 021 073 1 OEM, 900 104 003 02 M20, N 020 825 1 M20, 900 123 005 00 M131, 999 134 018 02 OEM Buenos Aries must have a Porsche dealership to help with correct part selection. Good Luck.
1987 Carrera 3.2 |
pszemia already has the pressure-fed tensioners installed. I believe the current issues involve the correct part number for the left side oil supply line and the recommended support brackets.
These parts are interchangeable all the way back to when they had a different chain box cover design (1966?). The replacement parts are on Pelican's parts catalog page: http://www.pelicanparts.com/catalog/shopcart/911E/POR_911E_ENGoil_pg4.htm#item13 Andrew M had this kit for sale awhile back: FS: Chain Tensioner Kit ![]() Match the pieces with the part numbers on Pelican's catalog page. Notice the cushioned, metal support brackets installed on each tensioner supply tube. It's also recommended to use the later, improved '81-on idler arms. You'll have to remove the chain box covers to see what you currently have. Sherwood |
Author of "101 Projects"
Left side oil line is correct, as Sherwood pointed out...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
there's a update on the left side rubber and metal line. the T fitting has been moved inward a bit, so if you order the all metal line, you get the one that fits the updated rubber and metal line, so you need both. or bend the all metal line to fit.
Somatic Negative Optimist
And don't forget the small O-ring on the tensioner shaft to seal the oil line hole in the chain cover.
Page 175 in Wayne's Engine Rebuild Book.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
thanks everybody, i am going to buy new all the lines, the all metal and the metal/rubber ones, so i don't have compatibility problem..
Also buying seals, new nuts, and o-ring so i don't have that tedious leaking anymore. ariel
pszemia:
Take note of this quote below: Quote:
You don't want to try to return something all the way back to California from "Beautiful Buenos Aires". Check to make sure. Good Luck.
1987 Carrera 3.2 |
thanks for advice sig_a
I've ordered all the lines from the same page, according to a PET for a carrera 1987-1989. I think, those lines are the right ones.
