the gremlin hiding in my engine bay
Hi, my Carrera has a minor issue, and I am in need of some veteran advice. I own an 88 with 102k on the clock. It runs well and exhibits no problems other than what is outlined below. Upon cold start, the car does not settle at a normal cold idle, but tries to drop immediately to 600-700 rpm. As you can imagine, it struggles a bit to maintain that. On occassion, it will pop to 1200 rpm or so for a moment, at which speed it is smooth and unstresed, before again trying to idle at 700. Additionally, once the car is warm, it will idle 500-600, which I believe is still about 200-300 rpm below where it should be. Whether hot of cold, once off idle, the flat six pulls smooth and strong and responds well. Of final note, the car may also a exhibit a gentle surging during part-throttle acceleration between 2000rpm and 3000rpm, but it so slight that I may just be paranoid, or unrelated. Thanks in advance for any advice you can give
Dan
Old 08-01-2008, 01:55 PM
Mad scientist
Peter Bull's Avatar
It might be a faulty engine temperature sender, or the wire to it.
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 08-02-2008, 12:21 AM
Is it a 930? You don't say... but from your name it looks like it.
Old 08-02-2008, 07:02 AM
Temp sender. Okay, I'll keep you posted. Thanks for the suggestion
Old 08-02-2008, 11:52 AM
My car is an 88 Carrera
Old 08-02-2008, 11:53 AM
I would start by having my mixture checked and adjusted to spec. before replacing parts that are perfectly good.
Old 08-02-2008, 12:50 PM
Sounds great, thanks. I'm a big fan of not spending money that doesn't need to be spent.
Sorry for the confusion. My car is a 1988 911 Carrera. The 930 only carried both "Carrera" and "Turbo" designations in '75 and '76. So by saying that my car was a Carrera, and metioning the year (88), I assumed I had made it clear. Again, I apologize for the confusion. Although this may have something to do with the mixture suggestion, because I was under the assumption that the Motronic management system set the fuel ratios electronically and therefor could not be adjusted. But if everyone was assuming that my car was a 930 because of my screenname, then I would understand the suggestion to adjust the (CIS) intermix ratio.
Old 08-05-2008, 08:54 AM
zbph10's Avatar
Have you checked the O2 sensor?
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 08-05-2008, 09:14 AM
Mixture on the Motronic is adjustable and very specific.
Old 08-05-2008, 05:47 PM
Great, thanks for the info, guys. i'll keep you posted
Old 08-07-2008, 08:45 AM
Laneco's Avatar
Check for vacuum leaks - including the intake runners to the heads. When you are satisified that there are none, move to mixture check/adjustment.
After that, well, do whatever the other guys tell you - the first two items have been successful for me on a couple of these cars.
angela
Hello
Old 08-07-2008, 09:40 AM
Check also the idle control valve.
Old 08-07-2008, 10:28 AM
I've never done a vacuum leak check before, If it's not too much trouble, could somebody outline the procedure for me? thanks
Old 08-07-2008, 12:05 PM
Oh, and no, I haven't checked the O2 sensor. By 'checked' do you mean replaced, or is there actually some way to test its function?
Old 08-07-2008, 12:09 PM
DW SD's Avatar
+1 - You can remove the ICV and plug the inlet line to which it is attached. Put it through the cold start routine and see if it exhibits the same behavior.
You can also try cleaning this device. I would use MAF cleaning spray or something compatible with electronic devices. carb or brake cleaner may cause issues.
Doug
1971 RSR - interpretation
Old 08-07-2008, 01:09 PM
scarceller's Avatar
Get the car running and idling then simply spray starter fluid around all the intake parts. Be sure to spray down in the 6 areas where the intake runners attach to the heads. If you have a vacuum leak the RPMs will go up when you introduce the spray.
The much better way to find these is with a smoke machine, you could ask the local mechanics who has one. They don't charge much for this test, my local guy charges $40.00 and it's well worth the money.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 08-07-2008, 01:24 PM
here is a thread on the idle air control.
3.2 idle control valve go bad
Rick
88 Cab
Old 08-07-2008, 01:36 PM
Got the starter fluid and MAF cleaner today, hope to get to them both this evening . . .
Old 08-08-2008, 12:51 PM
DW SD's Avatar
Others have used brake cleaner, from review of the other thread 3.2 idle control valve go bad . You can always use brake first and then use the MAF cleaner to ensure the contacts are good.
MAF cleaner is definitely less harsh.
Did you review the procedure for setting the idle mixture? You can do this at the same time as the ICV is removed.
Steve Wong has it on the www.911chips.com website, I think.
Good luck!
Doug
Old 08-08-2008, 01:16 PM
