911SC with Carrera Brakes and No Proportioning Valve
I have an 1982 911SC race car that I have discovered has Carrera brakes f/r but no proportioning valve as shown in this picture.
![]() I have had some undesirable results with too much rear brake and too much heat back there. When I look at the line shown in this picture it goes down to a "T" fitting for the front brakes. I does not make sense to me that I would put a limiting valve on the front brake line. Can someone help me with this?
82SC Track Car |
If you have Carrera brakes f/r then you need the Carrera 33bar p/v or an adjustable p/v on the rear brake circuit
Your arrow is pointing to where it should be. But from the pic that appears to be just a through fitting
Yes I have referenced your posts and web site trying to remedy my situation. Here is a picture of my car I don't know if this is a stock setup but I believe it is?? I don't know which line to work with here?
82SC Track Car |
![]() ![]() Take two
82SC Track Car |
Follow the hard lines off the m/c, stock, the forward one goes to the front brakes and the aft one goes to the rear brakes, each of those goes to a T which splits to L/R
Bill, thank you for your help. Here is a better picture of the line coming off the MC. I'll do some more searching to find a spot to locate the proportioning valve.
82SC Track Car |
Less brakes, more gas!
hrmnn... I have the same setup on my ROW and have not experienced any braking dislikes. If anything, my fronts got too hot once at Limerock... Can you describe more what you are feeling? I have considered the addition of the valve, but it never made the hit list as I had no issues.
Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
I've been eating through rear brakes faster than fronts. I've also had the rears lock up in wet conditions unexpectedly which was less than desirable
. This setup is ok for autocross type stuff but on a track it is just too much for me. I've learned to apply the brakes very gradually but I'd like to get the proper balance if I can. This is on a car running 235/245f and 275r.
82SC Track Car |
You could change your pads in the rear to a less aggressive pad, or move to a more aggressive pad in the front. Won't help much in the rain, though, so I guess you better install the PV.
AutoBahned
also gives a differential effect as the brakes go from cold to warm to hot... not he best but many people do alter the R pads
Carrera brakes are massively rear biased The smart thing to do w/ an SC is to use Carrera fronts only and leave the stock SC Ms on the back. Then there are no issues
Schleprock
Bill is correct. That arrow is not pointing to a pressure limiting valve. It's pointing to a union. The pressure limiting valve looks like a fat pale yellow-brown socket with some foam rubber wrapped around it
Kevin L '86 Carrera "Larry" |
When I removed the rear pressure limiting valve on my previous 86 Carrera, it really messed up the balance of the car at the track. It was the REAR that could actually boil the fluid, and I had far too much rear braking under threshhold braking into a turn at the track. Ended up putting the limiting valve (really just a spring loaded ball and socket device) back in.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
.Kevin, yup I stole your picture .
82SC Track Car |
How and were would would one plumb in a Tilton adjustable bias valve?
I was just talk with the guy who is going to do this for me. The plan is to cut a hole in the tunnel just aft of the front seats within reach of the driver and plumb it in there. I'm going to go with a rotary knob type adjuster vs. the handle 6 click position type. Infinite adjustment vs. defined adjustment levels.
82SC Track Car |
On a Carrera could one just plumb it in place of the limiting valve and put it on the dash?
No cutting. |
Maybe use flexible SS lines like at the wheels and make a kit out of it???
There are remote adjusters for some that could be run to the dash. Haven't seen any advertised in a long time though the usual cockpit adjustment is between the seats, this one is a hydraulic parking brake or line lock but an adjustable could be fitted here too. ![]() JMO but the Tilton positive click stops are the way to go, they are repeatable and won't vibrate off where they were set.
