mca mca is offline
mca's Avatar
Originally Posted by Brad w View Post
Hard to believe that the Alt just dies after taking the engine out. My starter also died and I had to have it rebuilt.
I installed a new wire harness so every time I have a issue I think thats the problem. For instance my alt has the internal regulator but the car was original with a external. So it makes me wonder....
Brad
Yep, very hard to believe. If the other tests GOOD then I will feel like fool b/c then it would indicate that the belt was too loose.
I think that it is great to have a new harness. Those things get pretty brittle after many years of heat cycling.
Regarding the change to the internal regulator ... wasn't that a pretty common thing to do? Have others experienced problems after the switch?
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 08-27-2008, 08:06 AM
mca mca is offline
mca's Avatar
It is official. I am an idiot.
The old alternator tested GOOD too.
I can now conclude that belt was slipping and not turning the fan / alternator. It is really amazing how one shim can make such a drastic difference.
I feel like it is incredibly tight right now. Much tighter than I have ever had it in 4 years of ownership. What a waste of time.
Old 08-27-2008, 02:01 PM
