gamatt's Avatar
Send a message via Yahoo to gamatt
What the $%^ does this switch do?
I have an 86 Cabriolet Carrera convertable. On the center console there is what appears to be a defrost switch slightly above and next to the A/C knobs. What is it for?
Gordon
Old 03-08-2009, 06:30 PM
geoz's Avatar
wing mirror heating
Old 03-08-2009, 06:35 PM
AKA SportsCarFan
FastCarFan's Avatar
I think it is a rear defrost switch. Although I guess your Cabrio doesn't have a rear defrost, maybe they used the same console for coupes & Cabrios, or maybe some PO put a coupe console in your Cabrio?
Doug Miller
1988 Guards Red Carrera
Old 03-08-2009, 06:37 PM
Carrera Cab Connoisseur
nyne11's Avatar
Originally Posted by geoz View Post
wing mirror heating
+1
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 03-08-2009, 06:50 PM
AKA SportsCarFan
FastCarFan's Avatar
wing mirror heating
I didn't even realize I have heated mirrors!
Doug Miller
Old 03-08-2009, 06:56 PM
gamatt's Avatar
Ok
Thanks. I need to open the console to get at the A/C motor speed switch anyway. I'll check the wing mirror wiring to see if that's it!
Gordon
Old 03-08-2009, 07:23 PM
boxster03's Avatar
Johnson Rod activator
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 03-08-2009, 07:28 PM
Driver
Noah930's Avatar
That would be the right-most pedal down in the driver's footwell.
1990 Black 964 C2 Targa
Old 03-08-2009, 07:53 PM
nyne11's Avatar
For the coupes it was a rear window demister and for the Cabs it was used to heat the wing mirrors. This was for ROW cars, not sure if the same applied for US/Canada vehicles. Easy to check, just remove the mirror glass and there should be an element visible on the back side with a 2 pin connector.
Dave
Old 03-08-2009, 08:23 PM
Talewinds's Avatar
So when is the button actually "on". It lights up when it is popped out but that seems counter-intuitive.
88' Carrera, Black/Black/Black, "Murdered Out" OEM.
06' BMW 'M' Roadster (Wife's car and WAY faster than mine)
Old 03-08-2009, 09:23 PM
gtc gtc is offline
abides.
gtc's Avatar
Pull it out to turn on. If your parking/headlights are on it should glow a bit when off, and light up more when you pull it out to turn it on.
Graham
1984 Carrera Targa
Old 03-08-2009, 10:03 PM
