What the $%^ does this switch do?
I have an 86 Cabriolet Carrera convertable. On the center console there is what appears to be a defrost switch slightly above and next to the A/C knobs. What is it for?
Gordon |
wing mirror heating
AKA SportsCarFan
I think it is a rear defrost switch. Although I guess your Cabrio doesn't have a rear defrost, maybe they used the same console for coupes & Cabrios, or maybe some PO put a coupe console in your Cabrio?
Doug Miller 1988 Guards Red Carrera |
Carrera Cab Connoisseur
Dave 1986 Carrera Wide Body Cabriolet 1993 Nissan 300ZX Twin Turbo (620rwhp) 2003 BMW 330Ci MSport Individual 1973 Mercedes 350 Custom Convertible |
AKA SportsCarFan
Ok
Thanks. I need to open the console to get at the A/C motor speed switch anyway. I'll check the wing mirror wiring to see if that's it!
Gordon |
Johnson Rod activator
Member #750 Early911S Registry 1970 911E I know Where Jerry S. has his NYC Garage Yadda Yadda Yadda |
Driver
That would be the right-most pedal down in the driver's footwell.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
For the coupes it was a rear window demister and for the Cabs it was used to heat the wing mirrors. This was for ROW cars, not sure if the same applied for US/Canada vehicles. Easy to check, just remove the mirror glass and there should be an element visible on the back side with a 2 pin connector.
So when is the button actually "on". It lights up when it is popped out but that seems counter-intuitive.
88' Carrera, Black/Black/Black, "Murdered Out" OEM. 06' BMW 'M' Roadster (Wife's car and WAY faster than mine) |
abides.
Pull it out to turn on. If your parking/headlights are on it should glow a bit when off, and light up more when you pull it out to turn it on.
Graham 1984 Carrera Targa |
Thread Tools | |
Rate This Thread | |
