abit off center
Why is my seatbelt mounting not metric?
My belt mounting is 7/16-20 hardware, is this some Nader American standard for belts or something?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
What?
Good old DOT specs.
Tom J. 911SC Cab SCWDP CaymanS |
"I am from the government and I am here to help you."
The same reason the speedometer stopped at 85 MPH for many years.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 08-21-2008 at 07:03 AM.. Reason: typos |
Slumlord
I think they are a bastard size to prevent people from replacing them with cheap bolts. Probably a good thing.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Cheaply made 7/16-20 bolts can be found if that's the objective. Naw, it's DOT spec for the multitude of cars purchased in the states.
The correct bolt is also easier to find than an equvalent high strength metric bolt (~ M12). Sherwood |
Slumlord
Why would the DOT care about commonization?
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
ALL safety equipment in the US has to be DOT approved, and in the US, SAE is standard, so that's what was spec'd including mounting bolts.
Headlights, brakes, seatbelts... Technically our H1 and H4 headlights are illegal for use on public roads; no adjusting tabs. For quite awhile, ONLY sealed beam headlights were legal, a throwback to the crappy lights earlier in the 1900's. The 85 mph speedos (with highlighted '55') were dictated for supposed fuel economy by the NHTSA under Jimmy Carter on all cars sold in the US. Lasted for about 3 years 80-82. Many Pcars of that era have had their speedos replaced w/ 150 mph units. Michelin developed radial tires and used metric units of measure. In the late 70's Michelin developed a metric wheel/tire size (TRX?) That I think only appeared on SAABs, Jaguars and some 'sporty' Ford models. Were expensive and did not catch on. Were roughly a 15-1/2" wheel, I think. Avon, I think also made the tires, too, for Jag. Disappeared after 10 years or so. Last edited by tcar; 08-21-2008 at 09:30 AM.. |
Thread Tools | |
Rate This Thread | |
