Weber vs PMO rain shields
I bought some rain shields from a Pelican member and they won't fit on my Weber 40 IDA's. Are the K&N bottom plates the same for PMO and Weber carbs? It looks like the holes are bigger as well. When I sit the air horns on top of the bottom plate I can see the outside edges of the holes where the air horn flanges are straight. Thanks in advance.
Mike.
1972 911T, non-sunroof coupe.
Old 08-26-2008, 03:03 PM
gumba's Avatar
The pmo bottom plates are different than the webers. Everything else is the same.
Old 08-26-2008, 04:22 PM
A quick search reveals that they are definitely for PMO's. Any chance they can be modified to fit the Webers (drilled). If I use a good gasket between the air horns and the base plates as well as between the base plates and carb top can I get away with it? That or I need to find someone that is willing to trade.
Mike.
Old 08-26-2008, 04:46 PM
