Injector capacity of a 3.2?
Anyone know what the HP limit is for the stock Carrera 3.2 injectors when running stock fuel pressures?
Will they support 300 fwhp?
Thx!
Old 08-27-2008, 08:54 AM
Will they support 350fwhp?
Old 08-27-2008, 08:59 AM
Friend of Warren
I am curious how you plan to get 300 hp out of a 3.2 without turbocharging or supercharging.
Oh and a stock 3.2 injector flows 240cc/min @ 45 PSI, 2.5 Bar pressure
Kurt V
Old 08-27-2008, 10:25 AM
1 bar = 14.503 773 801 pound/square inch
http://www.onlineconversion.com/pressure.htm
So 2.5 Bar must be 2.5 X 14.50 psi or 36.25 psi.
Stock Carrera fuel pressure is set at 2 Bar or 29 psi.
Old 08-27-2008, 12:05 PM
Steve W's Avatar
Correction, the stock fuel pressure is supposed to be 2.5 bar, but typically measure about 40 psi, vacuum line disconnected.
The injector capacity is similar to those used on the 964, with the 964s running 3.8 bar fuel pressure. 964 injectors at 3.8 bar run fine up to about 300 hp, but their control starts loosing linearity and gets sketchy as you approach 310-320 hp. On a 3.2 at 40 psi, about 270 hp is the max practical limit.
Old 08-27-2008, 12:18 PM
I was quoting "testing pressure at idle speed...approx. 2 bar" per Spec book, pg. 66, 84-87 911 Carrera, 911 Turbo Technical Specifications.
This is with the vacuum lines connected as a normally running 3.2 would be.
Old 08-27-2008, 01:27 PM
So to do 300 may require new injectors (944T) or a 964 fuel pressure reg.
Current 3.2 HP w chip and cat bypass, 217rwhp or 255fwhp at 6200rpm.
Bore and stroke to a 3.8 (102 nickies w stroked 76.4 3.2 crank) w proper mods to support. Could approach 300fwhp ((255hp/3.2)x3.8).
Second reference point, factory RS 3.8 makes 300 hp at 6500rpm.
Still very much at the dream / research stage. (I do have the car though.)
Old 08-27-2008, 03:41 PM
Oh, thanks Steve!
Love the chip!
Old 08-27-2008, 03:44 PM
abit off center
cgarr's Avatar
Steve, Would you start to see a lean condition as the injector reached its peak?
______________________
Craig
G2Performance
Old 08-27-2008, 04:04 PM
Steve W's Avatar
Pretty much. Either you'd see lean spikes if there loss of injector control, but you can tell when you keep increasing fuel map values and there's no change in the AFRs. On a 3.2 type motor, this has only happened on a highly prepped 3.2 race motor with a $4000 custom exhaust, in which case I needed to bump up the pressure by about 5 psi, or on a 3.2 to 3.7l street conversion, again where had to bump up the pressure.
Old 08-27-2008, 05:20 PM
How are you bumping the fuel pressure please?
What would be do without 911Chips.com to make our work!
Old 08-27-2008, 05:38 PM
Sorry.
What would we do without 911chips.com to make our mods work!!!
Old 08-27-2008, 05:41 PM
Steve W's Avatar
LOLs. There are adjustable fuel pressure regulators that you can buy special for the 3.2. The other way is to press the body of the regulator in a vice to place the internal spring under greater compression, which increases the diaphragm release pressure.
Old 08-27-2008, 05:52 PM
